Hello, so I recently made a build using the following parts:
i9-9900k
Gigabyte aorus h370 gaming 3 wifi
GeForce® GTX 1660 SUPER
Kingston HyperX FURY Black, 32GB, DDR4-2666MHz, CL16, Dual Channel
SSD Samsung 970 EVO Plus Series, 500GB, PCI Express x4, M.2
Hard Disk Seagate BarraCuda 2TB, SATA3, 256MB, 3.5inch
Corsair TX Series TX850M, 850W
Deepcool gamer storm assassin II, with 120mm and 140mm fans
The temperature of the pc have never gone over 70C.
On the motherbord I am using the latest bios, wich is F13. So I don't do any overclocking, the settings are normal, I didn't enable the xmp for the ram, but my problem is I'm getting random Blue screens. Some of them are: PAGE FAUL IN NONPAGED AREA, DRIVER_IRQL_NOT_LESS_OR_EQUAL. Also I get errors from Fortnite and Diablo 3, it crushes every time I have 32gb ram, when I only have 1 stick in the pc, everything works great.
All those blue screens comes from ram, as when I left just one stick of ram, I had no problems.
So I run Memory Check everything is good, the thing is this happens only when I have 2 sticks of ram in the pc, when I leave just one of them, everything works great.  Any suggestions what should I do? Everything is brand new, 1 week. I tested both ram sticks, one by one, they are good. The pc runs great with either of them.. but not with both of them togheter.
I have the sam ram sticks. from the same brand, same speeds.
https://linustechtips.com/topic/1130553-new-i9-9900k-build-problems-with-bsod/
Seems like one of your RAM modules is not working 100%.
If you can narrow it down which one exactly, maybe try replacing it with a different one and see if it works without crashing.
If that works, then RMA the defect kit, if you still can.
My Gaming PC:
Inno3D iChill Black - RTX 4080 - +500 Memory, undervolted Core, 2xCorsair QX120 (push) + 2xInno3D 120mm (pull)
AMD Ryzen 7 7800X3D - NZXT x72
G.SKILL Trident Z @6000MHz CL30 - 2x16GB
Asus Strix X670E-E Gaming
1x500GB Samsung 960 Pro (Windows 11 + 10)
1x2TB Kingston KC3000 (Games)
1x1TB WD Blue SN550 (Programs)
1x1TB Samsung 870 EVO (Programs)
Corsair RM-850X + native 12VHPWR-Cable
Lian Li O11 Vision
Alienware 360 HZ QD-OLED AW2725DF, MSI Optix MAG274QRFDE-QD, BenQ ZOWIE XL2720
Logitech G Pro Wireless Superlight 2
Wooting 60HE
Audeze LCD2-C + FiiO K3
Klipsch RP600-M + Klipsch R-120 SW
My Notebook:
MacBook Pro 16 M1 Pro - 16GB
Proxmox-Cluster:
  • Ryzen 9 3950X, Asus Strix X570E F-Gaming, 4x32GB3200MHz ECC, 2x 512GB NVMe ZFS-Mirror (Boot, Testing-VMs + TrueNAS L2ARC), 2x14TB ZFS-Mirror + 1x3TB (TrueNAS-VM), 1x 1TB Samsung 980 Pro NVMe (Ceph-OSD), Dual 10G NIC (Ceph), 2.5G NIC (VMs), 1G NIC (Cluster)
  • i7 8700k delidded undervolted, Gigabyte Z390 UD, 4x16GB 3200MHz, 2x 360GB HDD ZFS-Mirror (Boot), 1x 1TB Samsung 980 Pro NVMe (Ceph-OSD), Dual 10G NIC (Ceph), 2.5G NIC (VMs), 1G NIC (Cluster)
  • i5 4670, 3x4GB + 1x8GB 1600MHz, 2x 240GB HDD ZFS-Mirror (Boot), 1x 1TB Samsung 980 Pro NVMe (Ceph-OSD), Dual 10G NIC (Ceph), 2.5G NIC (VMs), 1G NIC (Cluster)
Proxmox-Backup-Server:
  • i5 4670, 4x4GB 1600MHz, 2x2TB ZFS-Mirror, 2,5G NIC
I will try to do that, as I have 2 pc's with the same specs, one for me and one for my brother (gift for new house) but he didn't have the time yet to configure his pc, so I will go ahead and install windows and everything on his pc also, if he have the same problems, than could be a motherboard issue... or don't know..
Just now, BuckyBallin said:
with most boards you want them in 2 and 4 for dual channel, is this pic from the manual for your board?
Yes, I can give you the link of the manaul.
https://download.gigabyte.com/FileList/Manual/mb_manual_h370-aorus-gaming-3wifi_1001_180628_e.pdf
2 minutes ago, Bogdan95 said:
I have them in slto 1 and 2, this is the picture of the slots on the motherboard:
check your motherboard manual, but as Bucky says, it's usually 2 and 4, or sometimes 1 and 3. that should solve your problem.
I will do that today, and I will come back. If that is the case, it will be great
Just now, Bogdan95 said:
THis is what I found in the manual:
So the guy who installed my memory, inserted them in 1 and 2, but I can see that the channel A is DDR4_2 and DDR4_4 or DDR4_1 and DDR4_3... so that could be my problem...
yeah so he installed in slots 1 and 2 instead of DDR4_1 and DDR4_2. So yeah, go for slots 2 and 4 (DDR4_2 adn DDR4_1).
It doesn't matter what brand you get, they all have a couple of failures. Had the same problem with my Corsair Vengeance LPX 3000mhz CL15 (just pointing out the exact model). One wasn't working, so I got it replaced with the same model and no problems at all.
MAIN PC:
CPU: AMD Ryzen™ 7 7800X3D Motherboard: Gigabyte B650 Eagle AX CPU Cooler: EVGA CLC 240 GPU: EVGA RTX 3080 FTW3 Ultra RAM: TEAMGROUP Expert T-Create 32GB (2x16GB) 6000Mhz CL30
Case: CoolerMaster TD500 Mesh PSU: Thermaltake GF1 PE 750w Storage: 1TB Western Digital Blue 3D + 1TB Crucial P1 + 1TB ADATA XPG Gammix S11 Pro + 4TB Seagate Barracuda 5400RPM OS: Windows 10 Home
Headphones: Philips SHP9500s   Keyboard: Corsair K70 RGB MK.2 Cherry MX Red Displays: Gigabyte M27Q (27" 1440p 170hz IPS), Samsung UN32EH4003FXZA (32" 768p 60hz TV)
Former parts that I've used:  Intel® Core™ i3-9100F, Intel® Core™ i9-9900k, Asus Dual OC 2080, Gigabyte Aorus Master 3080, Gigabyte Gaming OC 3080, EVGA XC3 Ultra 3080, EVGA FTW3 Ultra 3080 Ti, EVGA 3060 XC, ASRock Z390 Phantom Gaming 4-CB, Gigabyte Z390 Aorus Pro Wifi, ADATA XPG 16GB (2x8GB) 2400Mhz CL16, Corsair Vengeance 32GB (4x8GB) 3000Mhz CL15, Scythe Fuma 2, Acer XG270HU.
Today I will go to configure my brother pc, which have the same specs, if he have the same problems, that means could be related to GPU or MOTHERBOARD.. I will come back with an update.
1 hour ago, Bogdan95 said:
So I decided to run a Memtest. Look at all this errors...
Rma the ram stick and take exact same model
I Use my knowledge as business owner and self taught technician aswell as an AI to help people. AI might be controversial but it actually works pretty well 90% of the time.
  • 2 weeks later...
