Help with blue screen after ram OC
Bluuz
3700x with MSI b450 carbon.
16gb of g skill rgb: 3600, cl 18.
So i've followed ram overclocking guides:
exported my settings from thaiphoon, plugged them into ryzen mem calculator.
Picked safe preset and put in the settings from the 'main' and 'advanced' tab in my bios.
Ran memtest64 and got a blue screen. Very disappointed that even the safe preset doesn't work. What do I do now? Which of the 40+ settings can I dial back to try to achieve a stable configuration? How do I even diagnose/troubleshoot this?
For reference, the crash dump from blue screen view, can I conclude the crash was caused by ram OC (cpu at stock)?
Dump File         : 120319-6546-01.dmp
Crash Time        : 12/3/2019 12:18:11 AM
Bug Check String  : IRQL_NOT_LESS_OR_EQUAL
Bug Check Code    : 0x0000000a
Parameter 1       : ffff8784`ad7e1810
Parameter 2       : 00000000`00000002
Parameter 3       : 00000000`00000000
Parameter 4       : fffff802`0a8440c6
Caused By Driver  : ntoskrnl.exe
Caused By Address : ntoskrnl.exe+1c14e0
File Description  : NT Kernel & System
Product Name      : Microsoft® Windows® Operating System
Company           : Microsoft Corporation
File Version      : 10.0.18362.476 (WinBuild.160101.0800)
Processor         : x64
Crash Address     : ntoskrnl.exe+1c14e0
Stack Address 1   :
Stack Address 2   :
Stack Address 3   :
Computer Name     :
Full Path         : C:\WINDOWS\Minidump\120319-6546-01.dmp
Processors Count  : 16
Major Version     : 15
Minor Version     : 18362
Dump File Size    : 1,131,492
Dump File Time    : 12/3/2019 12:19:24 AM
if u dont know how ram ocing works, dont even bother , because mhz gets negated by cas latency and vice versa
the only thing ur creating if u overclock ram without knowing what ur doing is system instability and a high potential of blowing up files / causing corruption on files and corrupting windows itself to the poitn where it wont boot anymore
theres also no such thing as dram calculator that actually works, because the timings a stick achieve is mostly on the sticks itself rather then cpu,  ofcourse its limited by the mem controller also  but each system achieve different timings
and even after all that, u need to run stress tests for ram  for atleast 3passes in memtest ( preferable all night ) and a minimum of 24hours in prime95   due to it able to crash after 15hours+
also there can be slight unstabilities even when u do pass stress tests and still cause file corruption ( mostly secondary timings unstable )
Processor         : x64
Stack Address 1   :
Stack Address 2   :
Stack Address 3   :
Computer Name     :
Major Version     : 15
There's no need to create multiple posts for the same exact thing. As I stated before have you verified Hynix on Chip ect?
The calculator works to some degree but not all the time. As an experienced Memory  OC'r I can help but you have to give back a little bit.
As @Valkyrie Lenneth stated memory OCing isn't easy any you need to know what your doing. Again more than willing to help.
I would ditch the calculator your not running B or E die chips based on the timings of your kit your not going to go from 22 tCL to 16 unless you drop frequency. Again need to know what you want to achieve no point of wasting time on something that isn't possible expectations have to be set.
But again more than willing to help get you where you want to be.
Internet Connection
My Rig: AMD Ryzen 9 3900X @ 4.3Ghz | Asus Prime X470-Pro | Corsair Vengeance RGB Pro 32 GB (4 x 8GB) DDR-4 3000Mhz OC'd @ 3400Mhz 16-20-20-38 |
EVGA RTX 2070 8GB XC Gaming OC @ 2145Mhz Boosted/ 1925Mhz Memory | WD SN750 500GB M.2 NVME | Gigabye 240GB SSD |
XSPC EX 360mm | Corsair XC7 RGB CPU WB | EK-Vector RTX 2080 | Alphacool Eisbecher D5 150mm Plexi | XSPC Fittings | XSPC FLX Clear 7/16" ID, 5/8" OD |
Corsair LL120 x6 | Corsair RM750x White 2018 | Corsair Commander Pro | Corsair Obsidian 500D RGB SE | Corsair RGB LED Lighting PRO Expansion |
Corsair Strafe RGB MK.2 | Corsair Ironclaw RGB Wireless 18,000DPI | Acer 32" 4K 60Hz HDR600 Cert. ET322QK CBMIIPZX |
Passmark Score
3dmark Score
PC Parts Picker Link to Build
Network
Netgear LBR20 LTE Router | Verizon Unlimited Prepaid Hotspot Plan
HP 2530-48G-PoEP Switch
Rasberry Pi 4 Running Pihole
Linksys Velop 3 Mesh Wifi AP's
Dont have much experience with Ryzen OCing, but with my 8700k an unstable Mem OC was "fixed" by upping the memory controller voltage.
But that probably wont work for you, since every RAM kit and CPU memory controller is different. Some kits wont ever reach those settings you try to archieve, just because you recieved a bad overclocker.
Try to increase the kits base XMP frequency little by little and see what is stable.
My Gaming PC:
Inno3D iChill Black - RTX 4080 - +500 Memory, undervolted Core, 2xCorsair QX120 (push) + 2xInno3D 120mm (pull)
AMD Ryzen 7 7800X3D - NZXT x72
G.SKILL Trident Z @6000MHz CL30 - 2x16GB
Asus Strix X670E-E Gaming
1x500GB Samsung 960 Pro (Windows 11)
1x2TB Kingston KC3000 (Games)
1x1TB WD Blue SN550 (Programs)
1x1TB Samsung 870 EVO (Programs)
Corsair RM-850X
Lian Li O11 Vision
ASUS ROG Swift OLED PG27AQDM (240hz OLED), MSI Optix MAG274QRFDE-QD, BenQ ZOWIE XL2720
Logitech G Pro Wireless Superlight
Wooting 60HE
Audeze LCD2-C + FiiO K3
Klipsch RP600-M + Klipsch R-120 SW
My Notebook:
MacBook Pro 16 M1 - 16GB
Proxmox-Cluster:
  • Ryzen 9 3950X, Asus Strix X570E F-Gaming, 2x32GB3200MHz ECC, 2x 512GB NVMe ZFS-Mirror (Boot + Testing-VMs), 2x14TB ZFS-Mirror + 1x3TB (TrueNAS-VM), 1x 1TB Samsung 980 Pro NVMe (Ceph-OSD), 10G NIC
  • i7 8700k delidded undervolted, Gigabyte Z390 UD, 4x16GB 3200MHz, 1x 512GB SSD (Boot), 1x 1TB Samsung 980 Pro NVMe (Ceph-OSD), 2,5G NIC
  • i5 4670, 3x4GB + 1x8GB 1600MHz, 1x 512GB SSD (Boot), 1x 1TB Samsung 980 Pro NVMe (Ceph-OSD), 2,5G NIC
Proxmox-Backup-Server:
  • i5 4670, 4x4GB 1600MHz, 2x2TB ZFS-Mirror, 2,5G NIC
try dram voltage 1.4 v. that should do it.
Yes, verified on Thaiphoon.
Manufacturer             : Hynix
Part Number              : H5AN8G8NCJR-TFC
The kit is Cl18: https://ca.pcpartpicker.com/product/6jBTwP/gskill-trident-z-rgb-16gb-2-x-8gb-ddr4-3600-memory-f4-3600c18d-16gtzrx
3600mhz, 18-22-22-42
Reason I settled for this kit is that b-die chips are nearly 3x as expensive.
So are you looking to stick with the 3600Mhz frequency and setting tighter timings? Or just OCing the frequency?
Internet Connection
Passmark Score
3dmark Score
Network
Mostly looking to tighten timings, but I don't mind trying to push up the frequency too.
Okay personally since the timings on this kit are not the greatest and your already at 3600Mhz I think focusing on tighting the timings would give better gains then increasing frequency.
As I have stated before 3600Mhz ram speed gives you 1:1 infinity fabric which is best for performance, On Avg most CPU Fclk can only get up to about 1866 which would give you 3766Mhz memory and at that speed might require timings to be increased even further.
So I would start with this and see if you can boot
Frequency 3600Mhz  --  DRAM Voltage 1.38v  --  VTTDDR Voltage 0.70v  --  SOC Voltage 1.1v
tCL 16
tRCDWR 16
tRCDRD 20
tRP 20
tRAS 37
tRC 57
Disable GearDown Mode
Set 1T Command Rate.
Leave all other settings on Auto and lets see what happens to start here.
Internet Connection
Passmark Score
3dmark Score
Network
tCL 16
tRCDWR 16
tRCDRD 20
tRP 20
tRAS 37
tRC 57
I'll give this a try, however, these seem similar to the numbers I plugged in above (see dram calculator screenshot):
3600Mhz at 1.35v dram, 0.673 VTTDDR, 1.1v SOC
tCL 16
tRCDWR 18
tRCDRD 20
tRP 20
tRAS 36
rRC 56
which resulted in successful boot. blue screen during memtest64.
tCL 16
tRCDWR 18
tRCDRD 20
tRP 20
tRAS 36
rRC 56
Okay bump voltage up to 1.4v don't worry ddr4 can handle up to 1.5v as long are you have some fan cooling going over them.
Try this
tCL 16
tRCDWR 20
tRCDRD 20
tRP 20
tRAS 38
rRC 58
But give that first set a try first if that doesn't hold try this also you can bump that first set DRAM voltage to 1.375
Internet Connection
Passmark Score
3dmark Score
Network
  • 1 year later...
