Hi, my PC currently has a 512 GB M.2 SSD for the OS and a few games I play almost everyday. Otherwise, I have a 1 TB 7200 RPM hard drive for less frequent games (games I might play 2 times a week or less). My 1 TB Hard drive is filling up fast and want to replace it. Would getting a 5400 RPM drive be a lot slower, I only ask because finding a cheap 7200 RPM 4 TB hard drive seems difficult?
5400 RPM Hard drive: https://www.canadacomputers.com/product_info.php?cPath=15_1086_210_212&item_id=091921
7200 RPM Hard drive I was considering but has less space: https://www.canadacomputers.com/product_info.php?cPath=15_1086_210_212&item_id=132494
https://linustechtips.com/topic/1130523-5400-rpm-vs-7200-rpm/
If you only use the hard drive for games I guess it would work fine but obviously loading times would be a bit slower. I personally only use 7200 RPM hard drives so I don't have much experience with 5400 RPM drives.
Intel Core i9-10900X, Asus TUF X299 Mark 1, 128GB DDR4 3200MHz, Asus GTX 1080 Strix, 2TB 970 EVO Plus, 2TB SN570, 8TB HDD, DC Assassin III, Meshify 2
Old PC: Intel Xeon X5670 6c/12t @ 4.40GHz, Asus P6X58D-E, 24GB DDR3 1600MHz, EVGA GTX 970 ACX 2.0, 500GB, 250GB & 120GB SSD, 10TB & 2x 4TB HDD, Fractal Define R5
PC 2: Intel Xeon E5-2690 8c/16t @ 3.3-3.8GHz, ThinkStation S30 (C602/X79), 64GB (4x 16GB) DDR3 1600MHz, Asus GeForce GTX 960 Turbo OC, 1TB Crucial MX500
PC 3: Intel Core i7-3770 4c/8t @ 4.22-4.43GHz, Asus P8Z77-V LK, 16GB DDR3 1648MHz, Asus RX 470 Strix, 1TB & 250GB Crucial MX500 and 3x 500GB HDD
Laptop: ThinkPad T440p, Intel Core i7-4800MQ 4c/8t @ 2.7-3.7GHz, 16GB DDR3 1600MHz, GeForce GT 730M (GPU: 1006MHz MEM: 1151MHz), 2TB SSD, 14" 1080p IPS, 100Wh battery
Laptop 2: ThinkPad T450, Intel Core i7-5600U 2c/4t @ 2.6-3.2GHz, 16GB DDR3 1600MHz, Intel HD 5500, 250GB SSD, 14" 900p TN, 24Wh + 72Wh batteries
Phone: Huawei Honor 9 64GB + 256GB card Watch: Motorola Moto 360 1st Gen.
General X58 Xeon/i7 discussion
Some other PC's:
Some of the specs of these systems might not be up to date
PC 4: Intel Xeon X5675 6c/12t @ 3.07-3.47GHz, HP 0B4Ch (X58), 12GB DDR3 1333MHz, Asus GeForce GTX 660 DC2, 240GB & 120GB SSD, 1TB HDD
PC 5: Intel Xeon W3550 @ 3.07GHz, HP (X58), 8GB DDR3, NVIDIA GeForce GT 640 (GPU: 1050MHz MEM: 1250MHz), 120GB SSD, 2TB, 1TB and 500GB HDD
PC 6: Intel Core2 Quad Q9550 @ 3.8GHz, Asus P5KC, 8GB DDR2, NVIDIA GeForce GTX 470, 120GB SSD and 500GB HDD
HTPC: Intel Core2 Quad Q6600 @ 3.0GHz, HP DC7900SFF, 8GB DDR2 800MHz, Asus Radeon HD 6570, 240GB SSD and 3TB HDD
WinXP PC: Intel Core2 Duo E6300 @ 2.33GHz, Asus P5B, 2GB DDR2 667MHz, NVIDIA GeForce 8500 GT, 32GB SSD and 80GB HDD
RetroPC: Intel Pentium 4 HT @ 3.0GHz, Gigabyte GA-8SGXLFS, 2gb DDR1, ATi Radeon 9800 Pro, 2x 40gb HDD
My first PC: Intel Celeron 333MHz, Diamond Micronics C400, 384mb RAM, Diamond Viper V550 (NVIDIA Riva TNT), 6gb and 8gb HDD
Server: 2x Intel Xeon E5420, Dell PowerEdge 2950, 32gb DDR2, ATI ES1000, 4x 146gb SAS
Dual Opteron PC: 2x 6-core AMD Opteron 2419EE, HP XW9400, 32GB DDR2, ATI Radeon 3650, 500gb HDD
Core2 Duo PC: Intel Core2 Duo E8400, HP DC7800, 4gb DDR2, NVIDIA Quadro FX1700, 1tb and 80gb HDD
Athlon XP PC: AMD Athlon XP 2400+, MSI something, 1,5gb DDR1, ATI Radeon 9200, 40gb HDD
Thinkpad: Intel Core2 Duo T7200, Lenovo Thinkpad T60, 4gb DDR2, ATI Mobility Radeon X1400, 1tb HDD
Pentium 3 PC: Intel Pentium 3 866MHz, Asus CUSL2-C, 512mb RAM, 3DFX VooDoo 3 2000 AGP
Laptop: Dell Latitude E6430, Intel Core i5-3210M, 6gb DDR3 1600MHz , Intel HD 4000, 250gb Samsung SSD 860 EVO, 1TB WD Blue HDD
Laptop: Latitude 3380, Intel Pentium Gold 4415U 2c/4t @ 2.3GHz, 8GB DDR4, Intel HD 610, 120GB SSD, 13.3" 768p TN, 56Wh battery
https://linustechtips.com/topic/1130523-5400-rpm-vs-7200-rpm/#findComment-13097485
it's impossible to objectively define a lot, but if 7200RPM HDDs aren't unbearable when you have tried SSDs 5400RPM may be bearable as well
Desktop benching:
https://linustechtips.com/topic/1130523-5400-rpm-vs-7200-rpm/#findComment-13097486
The speed is not really relevant.
Look at benchmarks and reviews.
Some 5400rpm drives will get higher performance than other 7200rpm drives, it just depends on the drive.
https://linustechtips.com/topic/1130523-5400-rpm-vs-7200-rpm/#findComment-13097489
IIRC the larger capacity drives make it so the head has to travel a shorter distance to access the data, thus making the actual spinning speed not that much of a difference...at least that's (very roughly) how it was explained to me once. I wouldn't, for example, get a small capacity 5400rpm drive.
Then again, I wouldn't get an HDD at all.
Storage: WD 750 SE 500GB, WD 730 SE 1TB GPU: EVGA RTX 3070 Ti PSU: Corsair SF750 Case: Streacom DA2
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
https://linustechtips.com/topic/1130523-5400-rpm-vs-7200-rpm/#findComment-13097546
