Trouble posting at 3200mhz
Go to solution Solved by Wolfy97,
On 12/2/2019 at 9:42 PM, Wolfy97 said:
Hello guys,
(this is my 1st post here so don't roast me too much). I have made for my brother his 1st gaming pc and i have problems with it and i don't know how to solve after going wide in the internet for this.
I have made him a PC with the next components:
mobo: b450m DS3H from gigabyte
cpu: ryzen 2600
ram: patriot viper at 3200mhz
gpu (atm is my 1080 in it since i am on a budget and i need my paycheck to buy him smth else)
PSU: 600W 80+ bronze from thermaltake Smart BM1
The problem: when i activate the XMP profile on the ram and save and exit from bios the PC wont post and the speaker makes 3 beeps pause 3 beeps and then it keeps rebooting. The only way i can fix this is shutting the computer down and then PSU for about 2 minutes. Is there any way to fix this or is the ram bad? i am on bios version F41,
Thank you!
Oh i used precision driver and i managed to get them to run at 2666 i think i could run them at higher speed but i need to change the socket and i mounted the cooler "bad" and i can't so thats that. Anyway thank you to the persons that try to help me :)
Hello guys,
cpu: ryzen 2600
Thank you!
https://linustechtips.com/topic/1130326-trouble-posting-at-3200mhz/
14 minutes ago, Saksham said:
does it work if you set the ram at 3000mhz? what about 2666?
I can't change to this speed in bios i tried but there was no option to manual change it. Is there a setting i need to activate outside of advanced memory settings?
Hello guys,
cpu: ryzen 2600
Thank you!
