Hey guys, so by end of play today my entire PC should be here, except I’m still waiting on my 3 case fans to show up, since apparently they’re getting shipped from China. So if they’re the only things I’m waiting on, the only fans in my rig would be the double 120mm on my rad which I planned to mount in an exhaust on the top.
If I run everything at stock speeds should I have an issue ripping a 3800x and 2080S in a Lian Li O-11 for a few days with just the two fans on my rad? Or would I be best just waiting until I get my fans
Gaming Build:
CPU: Ryzen 7 3800x   |  GPU: Asus ROG STRIX 2080 SUPER Advanced (2115Mhz Core | 9251Mhz Memory) |  Motherboard: Asus X570 TUF GAMING-PLUS  |  RAM: G.Skill Ripjaws DDR4 3600MHz 16GB  |  PSU: Corsair RM850x  |  Storage: 1TB ADATA XPG SX8200 Pro, 250GB Samsung 840 Evo, 500GB Samsung 840 Evo  |  Cooler: Corsair H115i Pro XT  |  Case: Lian Li PC-O11
Peripherals:
Monitor: LG 34GK950F  |  Sound: Sennheiser HD 598  |  Mic: Blue Yeti  |  Keyboard: Corsair K95 RGB Platinum  |  Mouse: Logitech G502
Laptop:
Asus ROG Zephryus G15
Ryzen 7 4800HS, GTX1660Ti, 16GB DDR4 3200Mhz, 512GB nVME, 144hz
NAS:
QNAP TS-451
6TB Ironwolf Pro
https://linustechtips.com/topic/1130289-lian-li-o-11-without-fans/
It would be fine.
Just mount the fans as intake instead for now
