Does the LG 27GL83A-B comes with a displayport 1.4 cable?
I'm planning on buying this monitor and i don't know if i should order an extra displayport cable that's 1.4.
On rtings it says that it comes with an HDMI and Displayport cable but it doesn't say what version it is.
In The Box
LG 27GL83A-B In The Box picture
  • Disc manual
  • Warranty info
  • HDMI Cable
  • DisplayPort Cable
  • Power Adapter & Cable
CPU: Ryzen 5 5600x | MB: Asus TUF Gaming B550-Plus | RAM: Crucial Ballistix RGB 16Gb 3200Mhz | GPU: Gigabyte GTX 1080 Windforce | Cooler: Scythe Fuma 2 | PSU: EVGA SuperNOVA 650 G2 | SSD: Crucial MX300 275Gb | HDD: WD Black 2Tb | Monitor: LG 27GL83A
The cable provided is just fine.
I had the same worry when i got my monitor, but i use the 1.2 that was in the package!
CPU:i7 9700k 5047.5Mhz All Cores Mobo: MSI MPG Z390 Gaming Edge AC, RAM:Corsair Vengeance LPX 16GB 3200MHz DDR4 OC 3467Mhz GPU:MSI RTX 2070 ARMOR 8GB OC Storage:Samsung SSD 970 EVO NVMe M.2 250GB, 2x SSD ADATA PRO SP900 256GB, HDD WD CB 2TB, HDD GREEN 2TB PSU: Seasonic focus plus 750w Gold Display(s): 1st: LG 27UK650-W, 4K, IPS, HDR10, 10bit(8bit + A-FRC). 2nd: Samsung 24" LED Monitor (SE390), Cooling:Fazn CPU Cooler Aero 120T Push/pull Corsair ML PRO Fans Keyboard: Corsair K95 Platinum RGB mx Rapidfire Mouse:Razer Naga Chroma  Headset: Razer Kraken 7.1 Chroma Sound: Logitech X-540 5.1 Surround Sound Speaker Case: Modded Case Inverted, 5 intake 120mm, one exhaust 120mm.
Oh alright thanks, and how long is it? i wanna have my pc at 3 feet from my monitor because it gets too hot in the summer lol.
It's longer than that.
Alright thanks!
