Little below tjmax. So it’s “ok”. Is it real world temps?
90*C should be fine, seeing as it's under a pretty strenuous load.
3 minutes ago, KSores said:
i was running aida 64 so it was under 100% looad
Were you stressing FPU alone? or a different combination?
FPU alone will result in higher temps so you might thermal throttle, though you will never see that kind of workload while gaming but it is possible in other scenarios, what's your vCore voltage under load? (Not VID)
Quote or Tag people so they know that you've replied.
There are arguments that after a certain temp silicon chips can degrade faster, and claims that manufacturer maximums are set so that while it will degrade slowly it may be faster than actually desired by the owner.  Some feel that the manufacturer max temp is fine, and these claims are garbage.  I’ve heard 75c, I’ve heard 85c, I’ve heard “whatever the manufacturer sets it at”
Anything under tjmax (100c) for a synthetic stress test is ok and is unlikely to produce temperatures that high during real world usage.
Unless you are doing renders etc where your cpu will be at full load constantly, I wouldn't be worried about a high temperature stress test.
Let it under 80 in realistic workloads and you probably fine.
Before you reply to my post, REFRESH. 99.99% chance I edited my post.
My System: i7-13700KF // Corsair iCUE H150i Elite Capellix // MSI MPG Z690 Edge Wifi // 32GB DDR5 G. SKILL RIPJAWS S5 6000 CL32 // Nvidia RTX 4070 Super FE // Corsair 5000D Airflow // Corsair SP120 RGB Pro x7 // Seasonic Focus Plus Gold 850w //1TB ADATA XPG SX8200 Pro/1TB Teamgroup MP33/2TB Seagate 7200RPM Hard Drive // Displays: LG Ultragear 32GP83B x2 // Royal Kludge RK100 // Logitech G Pro X Superlight // Sennheiser DROP PC38x
i set my voltage to 1.375 in my bios
and here is a HWmonitor screenshot image.png.607e86b684ee5d90c8a70bc23d45c56b.png
VID is useless since it's always inaccurate, if you can't see vCore in HWmonitor then try HWiNFO and check "sensors-only" when you run it and it's important to look at vCore at idle and under load so you can see the max and min
Have you tried stressing FPU only?
