Upgrading my wife's 2500 intel to a ryzen 2700x. Put eveything in and No post.... The cpu cooler lights up, but I get no display nothing. Removed a stick of ram, and same thing. Removed second stick of ram and now it power cycles itself, still with no display. Doesn't even wake the display. Ram is known working, GPU is known working. Motherboard is asrock a320m.
Dead CPU? Dead Motherboard? both are brand new. Did i do something wrong. I've built several PC's in the past, Ryzen is the only one to give me any issues
https://linustechtips.com/topic/1129990-trouble-shooting-motherboard/
If I'm not mistaken, the a320 board might need a bios update to run a 2700x. It's the first culprit I would look at.
Current Build
AMD Ryzen 2600
Stock cooler
Asus ROG B450f gaming Mobo
1tb SKHynix m.2
WD 1TB HDD
Asus ROG Strix RX 5700xt
Thermaltake Toughpower 650w DPS RGB 80+Gold
16 Gigs ddr4 3000 gskill ram
Phantek fans
Phanteks P400TG
Laptop
Eluktronics Prometheus XVII
Ryzen 7 5800h
32 gigs ddr4 Corsair ram
Nvidia rtx 3080 max-p
17.3 qhd 165 hrz screen
1tb Samsung m.2
1tb WD black m.2
