Power Supply for Sapphire R9 290 - 4Gb ddr5
Go to solution Solved by Juular,
Yep, my choice is the same :
Bitfenix FG550W for 70 EUR
but there's also two 650W units for a bit more :
Bitfenix FG650W for 76 EUR, multirail too but it has two 30A rails (with OCP set to 34A) on two PCI-e power cables, so if it will be unstable using one cable (which i highly doubt, hence my recommendation is 550W version) then you can connect it using two separate cables (and thus separate rails).
Corsair TX650M for 77 EUR, single rail, less trouble so to say, in return for less protection, but it can operate with more noise, Bitfenix is quieter.
Hello,
i have buy 1 R9 290 in Second hand. I add it in my system, i have turn compter ON and all was nice. After 20 minutes.... PowerSupply explode! xD
I add other Power Supply and.... after 40minutes.... Explode! :D
my older PowerSupply:
https://i.ibb.co/4db5VrX/73352243-734761653692159-5853046264073027584-n.jpg
My question is, is this Power Supply to weak or.... Maybe R9 have some problem??
Now i wanna buy:
Nox Urano VX 750W 80 PLUS Bronze Edition
or
Seasonic Core GM 650W Semi Modular 80PLUS Gold
What advice can u give me? Thankyou...
https://linustechtips.com/topic/1129848-power-supply-for-sapphire-r9-290-4gb-ddr5/
5 minutes ago, Theros said:
Oooohh ... 30A on +12V rail on 600W unit ? That's no good.
Where you're shopping at and what's your budget for PSU ?
Tag or quote me so i see your reply
2 minutes ago, Faisal A said:
If both of them died I think it is a hardware problem
R9 290 is a VERY power hungry GPU, 300W stock, you need a very serious PSU for it. No noname shit will bear with it (and that's exactly what OP were using), they're lucky it didn't pull the entire PC with it (or maybe it did, who knows).
around 60€
and i buy from here:
https://www.pcdiga.com/catalogo-pcdiga/componentes/fontes-de-alimentacao     or
https://www.globaldata.pt/componentes/fontes/atx-sfx-tfx
4 minutes ago, Theros said:
around 60€
https://www.globaldata.pt/componentes/fontes/fonte-bitfenix-formula-550w-80-gold-bp-fm550ulag-9r
A little bit over but that's the cheapest good enough unit that's in stock.
Cheap shit PSU will result in shit performance. And it can burn other thing as well like your house.
DO NOT SAVE MONEY ON PSU!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
When i ask for more specs, don't expect me to know the answer!
I'm just helping YOU to help YOURSELF!
(The more info you give the easier it is for others to help you out!)
Not willing to capitulate to the ignorance of the masses!
i really say thank you, for your help and spend time with my question, but...
My pc is:
mobo: PRIME-B250M-PLUS
Cpu: I5 6500
2x4GB DDR 4
If R9 required 750W.... that PSU is fine?
what about this ones?
or
My pc is:
  Reveal hidden contents
Cpu: I5 6500
2x4GB DDR 4
or
"Cheapest good enough"
That should say all!
In other words if its to expensive save up until you can afford.
It doesn't require 750W, total power consumption would be hardly higher than 400W, it's just that AMD recomends 750W minimum because they think that most 750W+ PSUs would be okay for it (they're wrong). Both of these units are rather bad, again, that one that i've linked is the cheapest unit i can recommend based from these two sites, there's no much choice on one of them so maybe you can link a couple of others so i see if there's something else. But that unit is very good, don't worry.
"Cheapest good enough" as in it's definitely good enough for that GPU, and it's the cheapest of the "good enough" units i've found on these sites. It's a very good unit, no cutting corners here.
Also a good PSU can outlive multiple computers.
Meaning buy new computer you can still use the PSU so you dont have to buy that new.
Yep, and that's the case with the PSU i've linked, it's one of the best PSUs on the market.
Last question:
I read r9 290 need minimum 31A in +12rail....
This BitFenix u recommend only have 30A .... it's ok?!
edit:
I'm realy noob in PowerSupply's.... never understand 100% how they calculate what we need.... so, sorry for my questions. But i read all what of all of you say with very atention.
It's multi-rail unit, 30A per rail, four rails, your GPU requires two PCIe rails, so that's 60A total but it's rated ~45A total (12v * 45A = 550W) so it's good.
Edit: actually wait a minute, i'll look on this further. Do you have any other sites you can shop at anyway ?
im from Portugal, but maybe this site can help you (help me), in this >> site << we search what we are looking for, and that site give us the Cheapest price in all stores:
Nobody will do 'the work' for you. But if you look in this list get the best tier you can afford!
i dont need you do the job for me. I ask for help, and he wanna help me ( and i'm glad ), and the minumum i can make to help him is find one way so he can help me....
Ok, based on the review of 650W version, it has 140% OCP on 12V rails, so i think we can expect 550W unit to have configured the same. So 550W unit has only one PCI-e cable, with two connectors, and that's single rail. Now, 30A AMD recommends for R9 290 is about 370W, it ain't gonna consume so much on power average, that's failsafe number to accommodate for transient spikes. 550W unit has exactly 30A limit on paper and since OCP are set higher it'll be definitely good.
I'll see if there's smth else.
Thankyou once more for your Big help. I will buy that one Bitfenix FG550W !!! 2 power Suply have exploded but pc is 100% fine.... Let's se now! ;)
Big hug to you.
