Hi all.
I've never posted here before and am just looking for any advice or suggestions if anyone has any for someone who is fairly new to overclocking but not building rigs.
I have an old but solid setup that I want to use for video-rendering and audio production as well as gaming and recently bought a new set of RAM to update what I already had with this CPU / MB setup:
Asus X99 Deluxe MB
i7 5930k
GTX 970
(Old RAM) 4 x 4GB Crucial 2133MHz DDR4
New RAM is 4 x 8GB Corsair LPX 3200 MHz DDR4
I cannot get past a 53 code on the Asus X99 Deluxe MB with even just one stick of this RAM in ANY slot.
Code 53 is an error for no RAM initialisation and I've been searching around trying to find anything I could regarding this with no luck.
I get that XMP profiles are needed, I have a dedicated switch on the MB to enable this anyway and have profile 1 set on the BIOS but I can't post or even load up a video output or BIOS with one, two or all of the memory installed.
I've flashed the BIOS to the latest and then a couple of versions before the latest version to see what changes, nothing.
I've tried disconnecting drives and again, nothing.
I've read that the 5820k has probs with trying to use more than 2133MHz of RAM but the 5930k should not have this issue?
I don't know what else to try at this point and any help at all with this would be massively appreciated!
Thanks,
Steve
https://linustechtips.com/topic/1128616-i7-5930k-and-corsair-lpx-3200mhz-issue/
