Hi,
I recently bought Predator I7-9750,16GB RAM, 2060rtx
and now looking for a new monitor.
Basically I will be using it for gaming from close -ish distance for FPS and RPG and  movies(since don’t own tv so it is my main thing for watching anything) from 2m away.
Ideally looking for something that have at least 2.0 HDMI (I couldn’t find any 2.1) so for next year PS5 lunch I will be ready.
Still not sure is 27”-28” inch going to be enough ( if so I can go for QHD) or 32”is minimum.
And not fan of curved one since I still want to be married after I buy it ??
Any suggestions are more than welcome.
budget is around £400
So far I found this one
BenQ EW3270U £300
Thank you again hope someone can help
https://linustechtips.com/topic/1128555-32%E2%80%9D-4k-monitor/
Hi,
I found this one, it is similar just brightness is little high, every thing else same but much cheaper.
SAMSUNG U32J590 4K Ultra HD 32" LED Monitor
still hoping for some better deals tomorrow.
will see
thank you for post, if anything else pops up I will put it here.
https://linustechtips.com/topic/1128555-32%E2%80%9D-4k-monitor/#findComment-13085564
