Help choosing a new monitor
Go to solution Solved by Ozuhananas,
7 minutes ago, Streetguru said:
What kinda games do you play? Because you're right on the heels of getting a 240hz display that's pretty good
https://fr.pcpartpicker.com/product/nyMwrH/acer-xf250q-cbmiiprx-245-1920x1080-240-hz-monitor-xf250q-cbmiiprx
Otherwise just check the part picker, VA/IPS will be nicer for daily use in general, and always check reviews and stuff, but it's only 150-200 EUR for a 144hz 1080p display.
https://fr.pcpartpicker.com/products/monitor/#D=144000,240000&sort=price&A=3,2
Thanks a lot !
I play a lot of different types of games, but lately mostly Action-RPG and FPS (not competitive ones though) I would say. I don't know if a 240 Hz display is worth it for what I play, but this monitor looks really nice, I thank you for the suggestion and the advice for choosing on the part picker (didn't know this website before)
Hello,
Is there someone who can help me pick a new monitor ? I would like a 144Hz display with a size of maximum 27" and a vesa mount with a price range of  around 250-300 € (hoping it will go down with the upcoming sales here). A friend recommended me the BenQ ZOWIE XL2411P, is it any good or do you have any suggestion instead ?
https://linustechtips.com/topic/1128501-help-choosing-a-new-monitor/
1 hour ago, Ozuhananas said:
Hello,
Thanks a lot !
