PSU Help!? (please) Kinda Urgent
Hi, New to this forum
Looking for some advice please.
I've chosen all the components myself other than the PSU. I originally chose a Corsair RMx 750W 80 Plus Gold but was advised the one below would more than do for this build. Wanted a second opinion from a trustworthy and reliable source.
Here are the full specs:
Phanteks Enthoo Evolv X Midi
i9 9900k 3.6GHz LGA1151
be quiet! Straight Power 11 650W 80 Plus Gold****
Corsair RGB Lighting Pro Expansion Kit
Corsair ML120 Pro RGB 120mm Triple Fan Pack
Asus GeForce RTX 2070 sUPER 8192MB GDDR6
Samsung 970 EVO Plus 500GB SSD
Seagate Barracuda 2TB 7200RPM HDD
Corsair Hydro Series H115i RGB 280mm Liquid Cooler
Asus ROG Max XI Hero Z390DDR4 ATX
Corsair Vengeance RGB PRO 32GB 3600MHz DDR4
I would really appreciate an(other) expert opinion on whether this PSU will be fine? Thanks in advance.
https://linustechtips.com/topic/1128192-psu-help-please-kinda-urgent/
Thats good enough psu for your pc. Your pc will probably consume less than 500 watts when in stress.
I Use my knowledge as business owner and self taught technician aswell as an AI to help people. AI might be controversial but it actually works pretty well 90% of the time.
Those are both high quality units you wouldn't go wrong with.
I have actually used both those specific PSU's! (well, the older version of the RM750X..)
Looking at the PSU tier list, the Straight Power 11 is a step above the RMX series, but both would be more than sufficient for this build.
