Help, my mouse Is slower and starting to show some input lag, noticeable but not that big.
so yeah, my mouse isn't as fast, it's like its got some sort of smoothing, it's no longer as responsive as It should be, I tried higher dpi but It still was a problem, I tried everything like putting the enchant thing in the mouse settings and that didn't work so I turned It off again, honestly idk what to do, I had big input lag on my old pc and I'm not a week into my new pc and I'm starting to get the same feel to my PC.
Specs:
i5 6500
gtx 1060 6gb
8gb ddr4
If you guys want anymore information please tell me.
what is the mouse and how old is it?
Im with the mentaility of "IF IM NOT SURE IF ITS ENOUGH COOLING, GO OVERKILL"
CURRENT PC SPECS
CPU             Ryzen 5 3600 (Formerly Ryzen 3 1200)
GPU             : ASUS RX 580 Dual OC (Formerly ASUS GTX 1060 but it got corroded for some odd reasons)
GPU COOOER      : ID Cooling Frostflow 120 VGA (Stock cooler overheats even when undervolted :()
MOBO            : MSI B350m Bazooka
MEMORY          Team Group Elite TUF DDR4 3600 Mhz CL 16
STORAGE         : Seagate Baracudda 1TB and Kingston SSD
PSU             : Thermaltake Lite power 550W (Gonna change soon as i dont trust this)
CASE            : Rakk Anyag Frost
CPU COOLER      : ID-Cooling SE 207
CASE FANS       : Mix of ID cooling fans, Corsair fans and Rakk Ounos (planned change to ID Cooling)
DISPLAY         : SpectrePro XTNS24 144hz Curved VA panel
MOUSE           : Logitech G603 Lightspeed
KEYBOARD        : Rakk Lam Ang
HEADSET         : Plantronics RIG 500HD
Kingston Hyper X Stinger
and a whole lot of LED everywhere(behind the monitor, behind the desk, behind the shelf of the PC mount and inside the case)
15 hours ago, AdamWrld said:
It's a steelseries rival 110, got it for a about 1-2 weeks now, i tried it on another PC and It works fine.
is there a software for that mouse in the PC? if there is , try to uninstall and reinstall it.. if not check the mouse DPI in the mouse setting.
CURRENT PC SPECS
Okay just uninstalled and reinstalled It, dpi setting IS 800 on both settings. Also before this happened, my cpu fan cooler wasn't connected for about 5 days, but I never smelt burning or anything and I only used It for watching and stuff. Btw after reinstalling, I still the same.
Also I had this problem before and It was fixed by a update, i updated everything and It's the same, and before like when I first got my PC my mouse was fine until like a few hours of playing It would be like how It Is right now.
isnt 800 too low? ( #ImLockedAt6400DPIBecauseLowerThanThatIsTooSlow )
so it might have been software related since you said that it works on the other pc. have you tried it in another usb slot?
CURRENT PC SPECS
I have tried all usb slots, and I'm just saying that this wasn't a problem when I had the PC at the start and that had the software installed and 800 dpi is perfectly fine and Its how i play and I play fast with it.
at this point, it might have just been a software thing but im not sure which one. have you checked the USB headers inside the PC if they are connected properly? thats a bit of a stretch if its the problem but check , just in case. other than that, i dont know what is wrong.
CURRENT PC SPECS
I went through my pc and connected everything again, everything Is connected.
are we using thermal paste? sounds like the cpu is throttling cos the user doesn't know how to maintain a pc.
8 minutes ago, AdamWrld said:
I am using thermal paste.
can you monitor cpu temps?
Yes, I didn't actually know that my cpu fan was off for a few days so thats maybe why It happened, but I can run some temps rn.
please do
2 minutes ago, AdamWrld said:
probably without the fan the cpu would be at 50 or something since my pc Is pretty chilled and It's winter rn.
have you tried another mouse?
