Advice needed. Speaker sound distortion and display lag/freeze.
Hi and greetings to all.
I created this account to seek advice from you all tech savvy individuals and teams. I am not very tech savvy and English is not my native language, please forgives if there is any error in describing my issues.
I just migrated from intel to amd about a month ago and recently i facing weird sound distortion (fart like sound) and display lag/freeze. It happens once or twice per day and it lasted for 1-2 second. There are no graphical artifact but it is kind of annoying when it is happens.
It usually happens when i watch youtube or watch video in my hard disk. It also happens when i game. I ran furmark and MSI kombustor without any issue. At first, i though that the motherboard may have sound chip issue as previously i connect to sound jack at the rear port. But then when i try to use sound from the hdmi connection, it still have the same issue.
It is hardware or software issue? I really hopes it is not my GPU hardware problem, i bought the gpu on April this year and i never OC it as it already provide sufficient FPS for 1080p gaming.
My Pc Spec:
Ryzen 7 3700x
Galax RTX2080
XPG Spectrix D60G DDR4 3200Mhz 16GB kit
SX8200 Pro M.2 SSD
B450 GAMING PLUS MAX
1080p HDTV for Display
Remark : I did reinstall windows when migrating from intel to amd as previous windows installation is in sata SSD and my new rig use M.2 SSD as primary windows system drive. I did not use the old sata SSD due to planning to build second rig.
