so i currently have a 22 inch 1080p monitor. my sister wants to take it in exchange for a 40 inch monitor at 1080p. is that fine or will it be too pixelated?
Im with the mentaility of "IF IM NOT SURE IF ITS ENOUGH COOLING, GO OVERKILL"
CURRENT PC SPECS
CPU             Ryzen 5 3600 (Formerly Ryzen 3 1200)
GPU             : ASUS RX 580 Dual OC (Formerly ASUS GTX 1060 but it got corroded for some odd reasons)
GPU COOOER      : ID Cooling Frostflow 120 VGA (Stock cooler overheats even when undervolted :()
MOBO            : MSI B350m Bazooka
MEMORY          Team Group Elite TUF DDR4 3600 Mhz CL 16
STORAGE         : Seagate Baracudda 1TB and Kingston SSD
PSU             : Thermaltake Lite power 550W (Gonna change soon as i dont trust this)
CASE            : Rakk Anyag Frost
CPU COOLER      : ID-Cooling SE 207
CASE FANS       : Mix of ID cooling fans, Corsair fans and Rakk Ounos (planned change to ID Cooling)
DISPLAY         : SpectrePro XTNS24 144hz Curved VA panel
MOUSE           : Logitech G603 Lightspeed
KEYBOARD        : Rakk Lam Ang
HEADSET         : Plantronics RIG 500HD
Kingston Hyper X Stinger
and a whole lot of LED everywhere(behind the monitor, behind the desk, behind the shelf of the PC mount and inside the case)
https://linustechtips.com/topic/1127635-1080p-on-a-40-inch-monitor/
I wouldn't. That'll look absolutely horrible.
Then again, if you have shitty vision, you won't notice ?‍♂️
Storage: WD 750 SE 500GB, WD 730 SE 1TB GPU: EVGA RTX 3070 Ti PSU: Corsair SF750 Case: Streacom DA2
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
thats the thing. im the only one in the family that doesn't use glasses (im color blind though)
CURRENT PC SPECS
Your color blindness won't affect how you see the pixels. I'm color blind (partially) and yeah, 40" is way too big as a monitor. Are you sure it is a monitor and not a TV?
it is. its just a chinese brand of monitor. i plan to just buy a regular one in the future since 40 inch literally occupied my wall space LOL. ill be ditching it in about 2 months but im still worried about it though.
CURRENT PC SPECS
If I were you I wouldn't go for that big of a monitor at 1080p. I guess it depends on the person, but I personally wouldn't go over 23-24" at 1080p. Anything higher and I like 1440p/4K.
