Check user reviews at the major online merchants for DOA and other quality complaints. You will want to check each component choice. While generally the major brands tend to be more reliable, particular components may have issues.
Some companies offer international warranties. I'd buy something from one of those.
Storage: WD 750 SE 500GB, WD 730 SE 1TB GPU: EVGA RTX 3070 Ti PSU: Corsair SF750 Case: Streacom DA2
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
how long the vendor warranties the products is the best indicator and will give you the long term security.
in the hdd space, there is more enterprise reliable drives. those have higher MTBF and longer warranties (and may include data recovery services).
hdd storage is the one area where reliability is something you want to investigate. also consider raid 1 mirror for extra reliability for failures and backup your data externally (for example to the cloud).
you can replace any computer part but you do not want to lose your data.
