Hi guys! I'm in the process of deciding which parts to pick for my first self-built (gaming) PC. I have chosen some components but I do not have experience with building a PC so I used pcpartpicker for compatibility checker. I know some aspects aren't covered by the website so it would be great if someone could point out some potential compatibility issues, obvious bottlenecks etc. I also couldn't decide on the case and an HDD and I need help on picking these two. The case should be available in Europe.
Link to build: https://pcpartpicker.com/list/nyLVcq
Thanks a lot!
(Helpful list of cases available at the store in my country where I will buy the rest of the components -- https://www.pcgarage.ro/carcase/ )
you got yourself a super low end power supply for a super high end rig. Try a more affordable SSD like a Sabrent Rocket and use the money saved for a Corsair TXM. Since this is a gaming PC the cheaper SSD won't make any performance difference.
Primary PC:
Thank you. Any tips for the case and HDD @Fasauceome?
The new Lian Li lancool ii looks promising, and for HDD it's hard to go wrong with wd blue
Primary PC:
