I don't know what's going on with my computer. But I can't seem to connect my phone up to my computer.I tried reinstalling the software that allows my phone. To be able to transfer files between my phone and the computer. But whenever I go to do that.it won't install the software that's needed for that.that means I'm having trouble syncing upand transferring content between my phone and my computer fru a USB cable and flash drive I don't know what it is is it my phone or is it my flash drive not working properly help.I tried everything that I could think of to solve the issue but nothing I've done has worked in resolved this issue.
What software are you referring to?
I will complain about high prices in Norway given the oportunity.
Primary Desktop PC:
Hardware specifications:
CPU: i7-6700K @ 4.4GHz Motherboard: ASUS Z170 S CPU Cooler: NZXT Kraken x52 RAM: Crucial 16GB DDR4-2666 GPU: ASUS RX 5700XT ROG Strix SSD: Kingston Savage 240GB HDD: Seagate 3TB 7200RPM PSU: Corsair RMx 750W Case: NZXT H440
I/O:
Monitor: ASUS 27' 1440p 165Hz | AOC 24' 1080p 60hz Keyboard: Ducky ONE 2 SF (Cherry MX Brown) Mouse: Razer Viper Ultimate Headset: Sennheiser HD 6XX AMP/DAC: Drop O2 + SDAC DAC/AMP
(PC Part Picker Link)
Primary Laptop:
Dell XPS 15 9500:
CPU: i7-10750H RAM: 32GB DDR4-2933 GPU: GTX 1650 Ti SSD: 1TB NVME Display: 15.6' 1920x1200
Is the phone screen unlocked?
If you're interested in a product please download and read the manual first.
Don't forget to tag or quote in your reply if you want me to know you've answered or have another question.
What phone do you have?  You shouldn't require any special software to copy files between the phone and computer.
as Ryan mentioned.
once you plug it in you should get a pop up message saying that a device has been connected.
then your toolbar should have a usb button you can press and choose what to do with the newly inserted device and choose file transfer.
then it should be visible in the pathfinder/explorer (don't know the name in english but the windows program you press to view your drives)
Anything i've written between the * and * is not meant to be taken seriously.
keep in mind that helping with problems is hard if you aren't specific and detailed.
i'm also not a professional, (yet) so make sure to personally verify important information as i could be wrong.
7 hours ago, BenTreece1987 said:
Yes
Some phones won't connect by default.  Plugging them in simply generates a notification you can (and must) click to choose a connection mode - power only, mass storage, or other (if present).
Yeah this.  They're trying to get you to install some software to transfer, at least on older phones, but it's not necessary.  You just have to change to mass storage then the PC just sees the phone as mass storage device.
Actually it's called Media Transfer Mode on my phone
-Scott Manley, 2021
Softwares used:
Corsair Link (Anime Edition)
MSI Afterburner
OpenRGB
Lively Wallpaper
OBS Studio
Shutter Encoder
Avidemux
FSResizer
Audacity
VLC
WMP
GIMP
HWiNFO64
Paint
3D Paint
GitHub Desktop
Superposition
Prime95
Aida64
GPUZ
CPUZ
Generic Logviewer
