Will my PSU be enough for my workstation?
Go to solution Solved by Slottr,
It will, but why are you getting a SFF power supply? The H210 has room for an ATX sized unit, and they're significantly cheaper
https://linustechtips.com/topic/1127229-will-my-psu-be-enough-for-my-workstation/
CPU: R5 3600 || GPU: RTX 3070|| Memory: 32GB @ 3200 || Cooler: Scythe Big Shuriken || PSU: 650W EVGA GM || Case: NR200P
Thanks. The NZXT h210 has airholes in the bottom which give the graphics card really good airflow and improved thermals when it isn't covered by a full sized PSU.
Ah that's fair I guess. But wouldn't the psu shroud restrict that?
34 minutes ago, AshesAndWool said:
There is a filter and holes at the bottom of the case and holes in the PSU shroud under the graphics card
Makes sense then. Looks just fine then
