Dropping Frames on Low Settings in Overwatch
Just like the title says, i'm dropping frames down to 110 FPS when I shouldn't be dropping that low (or so I think).
I have an RX 580, Ryzen 2400g, and 8GB of RAM. This SHOULD be more than enough to run the game on low settings and stay on the 150 FPS cap I placed.
Screenshot of the settings:
  Reveal hidden contents
what game??
AMD blackout rig
cpu: ryzen 5 3600 @4.4ghz @1.35v
gpu: rx5700xt 2200mhz
ram: vengeance lpx c15 3200mhz
mobo: gigabyte b550 auros pro
psu: cooler master mwe 650w
case: masterbox mbx520
fans:Noctua industrial 3000rpm x6
Just now, OlympicAssEater said:
oh shit im big retarded
AMD blackout rig
it depends on what map and how many character models are in each frame so it can drop frames a ton sometimes or gain a ton to
AMD blackout rig
i play warthunder and my frames are super high when im not around other tanks but when i am it can drop 20+ (sometimes more if theres alot of tanks) frames do to complex character/ non-static entity models
AMD blackout rig
uhh whats your ram speed
and uh you might not be able to get 150 fps on games with hardware like that
AMD blackout rig
3000 Mhz
I only care about getting at least 144 fps in online games, I could less about high fps in story games
