So about a few months ago I built my own pc using the following specs:
CPU: Intel Core i5- 9600k  3.70GHz
GPU: MSI GamingZ RTX 2060
Motherboard: MSI Z390-A PRO LGA1151
RAM: Corsair Vengence RGB Pro 16gb (2x8gb) 3000 MHz DDR4
Air Cooler: Cooler Master Hyper 212 RGB
Power Supply: Corsair CX 450M (Modular ATX)
Hard Drive: SeaGate BarraCuda 2TB
SSD: Samsung 250GB
As of recently my computer has been experiencing high CPU Usage when I have as much as two apps open like Fortnite and Discord.
The performance in Fortnite has gotten a pretty big downgrade since the first day I tried the PC out, Fortnite in High Setting gave me from 250-340 fps, but as of now in its lowest setting my fps are going from 67-120 fps when  I am standing still and when I look around they drop as low as 15-30 fps. I would really love if someone can help me because now a trend is starting that my game crashed whenever it wants to. I have attached an image as "evidence" and sorry for my grammar mistakes as english is not my first language but I try my best <3 :D
https://linustechtips.com/topic/1126931-pc-building-noob-that-needs-help-t_t/
Check the temperatures with Hwinfo, use sensor mode
Desktop benching:
36 minutes ago, ItsKevinOMG said:
I would 'End Task' snip & sketch and facebook gameroom, they're both stealing 5.8% CPU usage.
Even better, disable them from running at all.
10 minutes ago, ItsKevinOMG said:
They aren't supposed to be that high aren't they....
Those temps are fine
Alright Snip& sketch was just for the screenshot
1 minute ago, Syaoran said:
Do you have the latest windows version and GPU drivers? Not updating them could have a negative performance on games if you don't update them for a long time.
I just installed the new version of Windows and NVIDIA updates my gpu automatically
Put the CPU at least in game load? The temperature is so low, I dont think you're running anything demanding on it.
Desktop benching:
That could be the cause for your issues actually!
Turn that automatic setting off.
Deinstall your current GPU driver with DDU (Display Driver Uninstaller)  use safe mode,  then reinstall the GPU driver after you downloaded it directly from the Nvidia site!
99% sure that'd fix your issue!  :)
-Scott Manley, 2021
Softwares used:
Corsair Link (Anime Edition)
MSI Afterburner
OpenRGB
Lively Wallpaper
OBS Studio
Shutter Encoder
Avidemux
FSResizer
Audacity
VLC
WMP
GIMP
HWiNFO64
Paint
3D Paint
GitHub Desktop
Superposition
Prime95
Aida64
GPUZ
CPUZ
Generic Logviewer
