Hi all I am starting a new build but here is one big issue the case needs to be fully air tight now I'm no engineer the best option I can see water cooling but having the rad outside the case and use silicone or epoxy to seal around the hoses but if any one knows of a better way I would love to know as I would like not to use water but if it comes to it then so be it
https://linustechtips.com/topic/1126817-cooling-in-a-air-tight-case/
Noctua has a lot of different cooling solutions for any situation,
If it's a very small case then the Noctua NH-L9i should work well (depending on the CPU).
A PC Enthusiast since 2011
AMD Ryzen 7 5700X@4.65GHz | GIGABYTE GTX 1660 GAMING OC @ Core 2085MHz Memory 5000MHz
Cinebench R23: 15669cb | Unigine Superposition 1080p Extreme: 3566
Just now, amdorintel said:
what dusty enviroment are you putting the pc into?
Its not so much a dusty environment this build is more of a on the road/feild build basically having a computer in a case to use out and about no matter the weather
If it's a small case then the Noctua NH-L9i should work well (depending on the CPU).
Thank you for the info and the exact parts are still undisided but I can say that hight will not be too constrictive
Doesnt have to be watercooled, you basically just want a passively cooled build. I'd personally just buy like a Compulab Airtop 2 and then stick a plastic bag over it if it rains.
How much clearance do you have?
There is the Noctua NH-D9L which is very beefy with height of 11cm.
There is the Noctua NH-L9x65 which is compact but beefy for it's size,the height is 5.1cm.
I have around 20 cm of clarance
Depends how powerful of a PC you require but we have some of theses units in industrial applications. If you plan to have it out in the field sticking it inside of a pelican case with a monitor and a battery pack will work great. Some even have 4G capability built in but they are pricey.
https://www.onlogic.com/computers/industrial/fanless/?product_list_limit=all
Then you can use the Noctua NH-D15,this is a beast of an air cooler,it even beat a lot of AIOs,the height is 16.5cm.
That is actually my idea but also makeing it fully water tight open or closed
That makes it a fair bit more complicated but doable using watertight pass-throughs for your required connectors. You can have the pelican case with wireless keyboards and monitors leaving the case itself as something to carry with separate connective devices to use the unit. What application is this being used in specifically?
Yeah in a LITERALLY air tight case, I can't see air cooling being possible. At all. Your only option should be water. Even then, you'll have loose rads hanging out unless you plan on mounting them on something. And even then, I don't know how you can make a case in regards to the case buttons and rear IO panel.
Gaming Build:
CPU: Ryzen 7 3800x   |  GPU: Asus ROG STRIX 2080 SUPER Advanced (2115Mhz Core | 9251Mhz Memory) |  Motherboard: Asus X570 TUF GAMING-PLUS  |  RAM: G.Skill Ripjaws DDR4 3600MHz 16GB  |  PSU: Corsair RM850x  |  Storage: 1TB ADATA XPG SX8200 Pro, 250GB Samsung 840 Evo, 500GB Samsung 840 Evo  |  Cooler: Corsair H115i Pro XT  |  Case: Lian Li PC-O11
Peripherals:
Monitor: LG 34GK950F  |  Sound: Sennheiser HD 598  |  Mic: Blue Yeti  |  Keyboard: Corsair K95 RGB Platinum  |  Mouse: Logitech G502
Laptop:
Asus ROG Zephryus G15
Ryzen 7 4800HS, GTX1660Ti, 16GB DDR4 3200Mhz, 512GB nVME, 144hz
NAS:
QNAP TS-451
6TB Ironwolf Pro
Well in regards to cable passthrou i am settled on anthanols line of water tight passthrous
For something with those needs off the shelf you may be looking at something closer to this than a unit that someone built themselves. As an alternative you could look into something like a Pansonic tough book or tablet as some of those are IP65 or IP 67 rated.
https://sdksys.com/products/waterproof-ip67-pc/rugged-waterproof-ip67-fanless-pc-detail/
https://na.panasonic.com/us/computers-tablets-handhelds/computers/laptops/toughbook-31
