RealTek drivers no sound
So ive had my headphones for a while now and i just newly installed RealTek drivers for them, since i had some problems with my mic. I havent used realtek drivers before with these headphones, i just did plug and play. Anyways, after i restarted my pc i couldnt get any sound from my headphones. Ive cheched everywhere if something was enabled or anything else disabled but icant find anything pointing towards no sound. Ive checked on google for similar things but ive so far not found anything that can/have helped me. I got the Logitech G430 without the little "USB adapter".
EDIT: with the "USB adapter" i got the sound working but now i dont have the realtek drivers and all the "enhancment" thingys for my microphone, and that is what i was after. I also lost the "enhancment" tab on the headphones so there are no bass boost or anything like that. I have to use the Logitech gaming software for bass boost but i cant seem to find anything usefull for the mic. The sound also seemed to work because its basically a totaly diffrent sound output in windows, like its not the same device.
https://linustechtips.com/topic/1126788-realtek-drivers-no-sound/
After unistalling the RealTek drivers my sound is back as normal! Without the USB thingy. WHY? I'll try to install RealTek Drivers once again to see if it was just a failed installation last time.
EDIT: After installing the RealTek Drivers for the 2nd time, the sound still dissapeared. I guess i'll just have to not use them. :,(
