hi!
ive been playing minecraft on my system and streaming it pretty well. i had a 1080p game on 75fps and a 720p stream at 60fps. only my game started to stutter and drop to 0 frames every time i walked a block
system:
motherboard: gigabyte aorus a450 elite
apu: ryzen 3 2200g with radeon vega 8 graphics
psu: corsair cx550
ram: G. Skill Aegis f4-300016D-16GISB
ssd: kingston a400 240gb
os: windows 10 pro
2 gigs are allocated for vram
things i tried:
turning off and on XMP
updating and reinstalling drivers
allocating more and less space for vram
problem 2:
my ram is 3000mhz but its running slower. since XMP is not working and makes windows not boot, i have to set it manually. i dont know how to set ram speed manually and would like some help for this.
Yeah, that APU isn't really sufficient for streaming and gaming at the same time. Really it's not the best for either alone. You'll probably need a beefier CPU and GPU if you want to stream your games.
Current LTT F@H Rank: 69    Score: 3,457,572,143    Stats
Yes, I have 9 monitors.
My main PC:
OS: Windows 11
CPU: Ryzen 9 3900X w/PBO on
Cooler: Noctua NH-D15
Mobo: Asus X470-F Gaming
RAM: 64GB G-Skill Ripjaws V @ 3200MHz
GPU: RTX 4090 Founders Edition, Radeon Pro WX 5100
PSU: Corsair RM1000e
SSDs: Samsung 970 evo plus 1TB NVME, 2x Samsung 870 evo 2TB, Samsung 860 evo 1TB, Samsung 970 evo 500GB NVME
Case: Fractal Design Define R5 Black w/ Tempered Glass Side Panel Upgrade
Monitors: 9 Monitors: Alienware AW3423DWF 3440x1440@165Hz, Acer H236HLbid 1080p@77Hz, HP D7z72AA 1080p@60Hz, Dell Inspiron 24 3459 1080p@60Hz(used only as display), Dell U2724D 1440p@120Hz, ASUS VP228 1080p@60Hz, 2x HP ZR2440W 1200p@60Hz
unRAID server (Plex, Backups, NAS, Duplicati, game servers):
OS: unRAID 6.12.4
CPU: Ryzen R7 2700x @ Stock
Cooler: Noctua NH-U9S
Mobo: Asus Prime X470-Pro
RAM: 16GB G-Skill Ripjaws V + 16GB Hyperx Fury Black @ stock
PSU: EVGA G3 850W
SSD: Samsung 980 Pro 1TB NVME, Samsung 970 evo plus 1TB NVME
HDDs: 4x HGST Dekstar NAS 4TB @ 7200RPM (3 data, 1 parity) + (3x Seagate Ironwolf NAS 8TB + 2x Toshiba N300 NAS 8TB in ZFS)
Case: Fractal Define 7 XL
Other: Added 3x Noctua NF-F12 intake, 2x Noctua NF-A8 exhaust, Inatek 5 port USB 3.0 expansion card with usb 3.0 front panel header
thanks for responding but it worked fine before, like i said in the first phrases of my topic. :)
It's not quite clear do you mean it worked,  or it only worked until you started to "walk a block"?  :)
Also sazrocks is kinda right that system isn't really sufficient for Streaming and gaming at the same time,  at least not without problems!
Lastly I think fixing your RAM would certainly help a bit, unfortunately I don't know enough about manually setting the RAM to help you with that.  So I hope someone else could help you out there.
-Scott Manley, 2021
Softwares used:
Corsair Link (Anime Edition)
MSI Afterburner
OpenRGB
Lively Wallpaper
OBS Studio
Shutter Encoder
Avidemux
FSResizer
Audacity
VLC
WMP
GIMP
HWiNFO64
Paint
3D Paint
GitHub Desktop
Superposition
Prime95
Aida64
GPUZ
CPUZ
Generic Logviewer
i could stream and play fine. after a while it started to act stupid. then the lag started when i tried to move or load chunks. i can now not even play the game without streaming without the inmense frame drops and just lag in general
