240mm AIO enough for ryzen 3950x?
Go to solution Solved by Deli,
1 hour ago, AshesAndWool said:
Hi guys, I am building a relatively small workstation and the NZXT supposedly fits both the corsair hydro h100i RGB platinum and the h115i but with the 115i its a really tight fit. Do you guys think a 240mm AIO will be good enough to cool a Ryzen 3950x? Thanks
If you plan to run the CPU at default, no overclock. Then yes.
Or, if you overclock but don't mind the high temperature, like 85C, then also yes.
My build:
https://linustechtips.com/topic/1126669-240mm-aio-enough-for-ryzen-3950x/
21 minutes ago, AshesAndWool said:
Do you really need an ITX system? Because preferably you'd use a 360mm AIO
Should also just get all NVME storage, it costs the same as those sata drives
You can get a windows 10 key for $5 on ebay
an RX 5700 at $329 ish will do just fine, even has image upscaling to cheat out 4k gaming.
You can get way cheaper RGB fans on Ebay and Aliexpress. Or just get a Coolermaster H500 maybe.
