i got a new rx 590 to use it with my old amd fx 8320 but the thing is that it doesnt even reaches 60fps in battlefield 4! i did use the aorus oc software to oc at 1560 and the performance was worse so i put it back to stock
is it bottlecking? my psu is not enough?  im planing to get a ryzen 5 2600
my specs are:
amd 8320e
gigabyte GA-78LMT-USB3 6.0
kingston blu 8gb dd3
aerocool strike x 600watts 80+ bronce
https://linustechtips.com/topic/1126610-rx-590-and-fx8320-low-fps/
That sounds about right.  8320e has about half the performance of a 2600.  Passmark implies You’re nice and cpu bound there.  Not a very accurate number of course, but probably accurate enough for this.
https://www.cpubenchmark.net/cpu.php?cpu=AMD+FX-8320E+Eight-Core&id=2374
20 minutes ago, madbutcher94 said:
5 minutes ago, Bombastinator said:
An FX 8 core should be able to get 100fps without an issue in that game, what settings were you at? should run 720p low or something to max out the CPU.
did you do a fresh install of windows?
playing at ultra 1080p. and i did not made a clean install
6 minutes ago, madbutcher94 said:
Then just run the game at lower settings, start with the lowest settings at 1080p
3 minutes ago, madbutcher94 said:
but why? i mean the 590 can do better than that, i was having more fps with my 750
It can, but I’m not sure your CPU can.  That’s what CPU bound means.  I wonder if the game maybe changed some settings automatically when it saw the 590.
this may have been what @Streetguru was getting at.
Your CPU is pretty bad, but what were you getting before with what card?
Storage: WD 750 SE 500GB, WD 730 SE 1TB GPU: EVGA RTX 3070 Ti PSU: Corsair SF750 Case: Streacom DA2
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
that CPU can do at least 90-100fps average in battlefield 4
By running it at the lowest settings you can see if it's a CPU issue, or GPU/Driver/Windows issue.
no idea why a 750 would get higher fps.
5 minutes ago, Streetguru said:
that CPU can do at least 90-100fps average in battlefield 4.
Yesssss... Depending on the settings.  This was the point I thought you might be making.  That his settings changed.
maybe it would get more fps because of the botteneck
7 hours ago, madbutcher94 said:
That's not how bottlenecks work, that CPU can get 100fps regardless of the GPU, probably try reinstalling windows, trying different drivers, and seeing how it does in other games.
The replied to post field is empty in your reply to @madbutcher94 so I’m not sure what you are referring to by saying this.  To test this, I will ask complicated annoying questions.  I apologize in advance.
annoying question:
Would it be more accurate instead  of saying “that CPU can get 100fps regardless of GPU” to say that “when settings are lowered enough even a CPU such as the fx8320e can generate 100fps”? or do you mean that “settings are irrelevant to CPUs and an fx8320e can generate 100fps for that game regardless of settings because those are affected only by GPU”? Or are both of these incorrect?
just trying to figure out what you are saying here.
annoying question:
There may be some CPU heavy options, but outside of those if you had a 2080ti you could do 4k gaming on it without issue.
That... Didn’t really answer the question.
