Hi everybody,
Does anybody know how i could create this build? Most mini itx motherboards have only one PCIE connection but this build they use extra pcie capture cards cards. Do they use m.2 to pcie? Does anybody has any idea any help would be very much appreciated. Thank you in advanced
1233445441_ScreenShot2019-11-22at11_51_23.thumb.png.b4c5279dcc0a6453078b08541558b95d.png1929454819_ScreenShot2019-11-22at11_51_15.png.447238572e9523a3538823e2b72ef3c4.png
https://linustechtips.com/topic/1126303-mini-itx-build-with-gpu-and-capture-cards/
Link plx
CPU: Ryzen 5800X3D | Motherboard: Gigabyte B550 Elite V2 | RAM: G.Skill Aegis 2x16gb 3200 @3600mhz | PSU: EVGA SuperNova 750 G3 | Monitor: LG 27GL850-B , Samsung C27HG70 |
GPU: Red Devil RX 7900XT | Sound: Odac + Fiio E09K | Case: Fractal Design R6 TG Blackout |Storage: MP510 960gb and 860 Evo 500gb | Cooling: CPU: Alphacool ST30 420mm rad, Alphacool CPU and GPU Core LT and Core blocks, D5 pump and res combo
They probably use a PCIe 3.0 16x riser that splits into 2 PCIe 3.0 8x slots.
Please mention or quote me if you want a response. :)
¯\_(ツ)_/¯
¯\_(ツ)_/¯
¯\_(ツ)_/¯
¯\_(ツ)_/¯
¯\_(ツ)_/¯
¯\_(ツ)_/¯
Are you sure it's not some USB 3 capture card connected into a usb 3.0 header?
Also, you can buy  pci-e switch things ... you insert it in a pci-e x8 or x16 and it takes the 8-16 lanes and creates multiple slots.
The cheapest are pci-e x1 to 2..4 x1 slots  ex: https://www.amazon.com/Cablecc-Express-Switch-Multiplier-Splitter/dp/B073QNW3L9/ref=sr_1_1?keywords=pericom+pci-e+x1&qid=1574424435&sr=8-1
Ok but they have a graphics card in it aswell so that will be using the only pcie 16 slot available but nice to hear your opinion thank you!
USB 3 is impossible 4 channel capture cards don't exist on usb yet but thank you for your thoughts.
3 hours ago, DoctorNick said:
Link plx
http://www.switchbladesystems.com/M7.html
2 hours ago, Billybonka said:
This is called PCIe bifurcation, I think mostly Asrock boards support it.
