So I think my laptop is using it's intel integrated graphics because when I right click on the desktop it shows intel graphics settings instead of the nVidia which should be appearing.
The laptop is using GT 940M, how would we know if the laptop is using the dedicated gpu?
Are you on battery or plugged in? Most laptops won't use the dGPU on battery.
Main PC
CPU: i5 12600KF
Cooler: Noctua NH-L12S
Motherboard: ASRock Z690 ITX/ax
RAM: 2x16GB 3600Mhz DDR4
GPU: Intel ARC A770 16GB LE
Storage: 1TB MP34 + 2TB P41 + 2x 1TB MX500
ODD: LG WH14NS40
PSU: EVGA 850W GM
Case: Silverstone Sugo 14
OS: Windows 11
Mouse: EVGA X17
Keyboard: Corsair K55 RGB
Mobile/Work Devices: 15" M3 MacBook Air (work) - iPhone 13 Pro Max - Apple Watch S3
Other Misc Devices: iPod Video (Gen 5.5E, flash, running Rockbox), Nintendo Switch
Vehicles: 2002 Ford F150, 2022 Kawasaki KLR650
Hey, we just noticed when we forced the control panel to start, it said there was no nvidia gpu connected to the display. How do we make the laptop use the nvidia GPU?
Does Task Manager or GPU-Z or Device Manager see the dGPU?
Did you try reinstalling the GPU drivers? (https://www.nvidia.com/Download/driverResults.aspx/153946/en-us)
Main PC
CPU: i5 12600KF
ODD: LG WH14NS40
PSU: EVGA 850W GM
OS: Windows 11
Mouse: EVGA X17
Battery is plugged in and we tried all that
What's the model # on the bottom of the laptop?
Main PC
CPU: i5 12600KF
ODD: LG WH14NS40
PSU: EVGA 850W GM
OS: Windows 11
Mouse: EVGA X17
1. Open the "Nvidia Control Panel".
2. Select "Manage 3D Settings" under 3D Settings.
3. Click on the "Program Settings" tab and select the program you want to choose a graphics card for from the drop down list.
4. Now select "preferred graphics processor" in the drop down list. (You can see what the automatic option is listed as global setting) If you want to use the dedicated graphics card, select High-performance Nvidia processor.
We can't open the nvidia control panel to begin with, when we open it from the source file on the C drive it says there is no detected display adapter
Go into the BIOS of the laptop (usually F2 or Del) while the computer is booting. Check to see if there is an option to disable the discrete GPU.
940M is about the same performance as integrated graphics to begin with.
Install GPU drivers from the manufacturers website.  With Optimus, you will get intel GPU settings and NV GPU settings.
Check device manager to see if both display adapters are present and no devices are experiencing problems.
