My pc starts, and then shuts down
Go to solution Solved by ItsNypz,
Fixed it by deleting the asio.sys folder in regedit.
About 30 seconds after I put my password and the pc already loaded, the pc shuts down and the same msg shows up.
it's in portuguese so i will translate:
An error occured in the computer and it is necessary to restart. Some informations about the error are being taken and after the pc will restart automatically.
25% concluded
Code for stop : System service exception
What failed : asl0.sys
The last thing I used the pc for was to run "ultimate defrag" on my pc and after running it I turned off now that I come back, the pc keeps restarting with this message.
https://linustechtips.com/topic/1125966-my-pc-starts-and-then-shuts-down/
https://forums.tomshardware.com/threads/blue-screen-of-dead-asio-sys-error.2942938/
this guy said he had the same problem and found a solution give it a go.
Anything i've written between the * and * is not meant to be taken seriously.
keep in mind that helping with problems is hard if you aren't specific and detailed.
i'm also not a professional, (yet) so make sure to personally verify important information as i could be wrong.
While the issue was the same my problem only happened 5 months after my upgrade so I dont thiink its the same thing. Also I can't put the hdd back to the other pc, it's the same pc but I changed some stuff on it
and you're sure it's not some drivers you're missing from asus?
does it restart instantly or do you have a small amount of time to try and download them?
hmmm.
i'm not familiar with how to do bios flashing but i'd suggest you find a video or ask some of the people here (there are many smart ones hiding) on how to do it.
