I've always wanted a portable PC for extended trips.  I really like this Lian Li Q37 Mini ITX case.  I would like to mount a display in the location below on the opposite side of the glass panel.
Does anyone body have the dimensions below? I'm curious what size monitor can fit that rectangular area?
This is a 5x3" monitor. I'd like to fit the largest I can. (The picture below is not to scale.) I'd like to connect it directly to MB using HDMI to USB 3.0 cable or something of the sor.
dkNZqbq.jpghttps://i.imgur.com/dkNZqbq.jpg
Can anyone with this case take these dimensions?
The components will look something like this. It should be around $3,500 w/ CPU/GPU water cooling and rigid tubing.
PCPartPicker Part List: https://pcpartpicker.com/list/Q9Xbhg
CPU: Intel Core i9-9900K 3.6 GHz 8-Core Processor  ($471.99 @ Amazon)
Motherboard: ASRock Z390 Phantom Gaming-ITX/ac Mini ITX LGA1151 Motherboard  ($169.99 @ Amazon)
Memory: Corsair Vengeance RGB Pro 32 GB (2 x 16 GB) DDR4-3200 Memory  ($169.99 @ Amazon)
Storage: Intel 660p Series 2.048 TB M.2-2280 NVME Solid State Drive  ($204.99 @ Amazon)
Video Card: Asus GeForce RTX 2080 Ti 11 GB ROG Strix Gaming OC Video Card  ($1279.99 @ Best Buy)
Case: Lian Li PC-Q37 Mini ITX Tower Case  ($336.13 @ Amazon)
Power Supply: Corsair SF 600 W 80+ Platinum Certified Fully Modular SFX Power Supply  ($139.00 @ Amazon)
Operating System: Microsoft Windows 10 Pro OEM 64-bit  ($139.99 @ Other World Computing)
Total: $2912.07
Generated by PCPartPicker 2019-11-20 20:37 EST-0500
https://linustechtips.com/topic/1125810-lian-li-q37-mini-itx-w-display/
