Probley more than more than one connecter on each cable...
Please quote or tag  @Ben17 if you want to see a reply.
If I don't reply it's probly because I am in a different time zone or haven't seen your message yet but I will reply when I see it ?
5 minutes ago, TechnicGeek said:
Hello,
This Gigabyte power supply has 5 PCI-e slots, correct? Including slots for CPU.
If yes, then why does Gigabyte's specifications say it has 6 slots?
Here is a screenshot.
That's 4 if you use the PSU to power the CPU.
Could be a typo or that they send 6 PCI-E cables.
or it could be like what @Ben17 said.
A PC Enthusiast since 2011
AMD Ryzen 7 5700X@4.65GHz | GIGABYTE GTX 1660 GAMING OC @ Core 2085MHz Memory 5000MHz
Cinebench R23: 15669cb | Unigine Superposition 1080p Extreme: 3566
8 minutes ago, TechnicGeek said:
Hello
What model is it though?
It doesn't have any slots.  It has connectors.
Also is it that hard to check the official page ?
See https://www.gigabyte.com/Power-Supply/GP-AP850GM#kf
You have 5  8 pin headers on the power supply. You can connect the 4 pci-e cables and one EPS cable if you want to.
Or. 3 pci-e cables and 2 cpu cables... up to you
Person above me nailed it on the answer with the image. But its four cables and two of them have two connectors per cable for anything with more than one 6 or 8 pin. Also I am fairly certain that you cannot use the cpu and pcie connectors interchangeably like that, they should be keyed differently and deliver different amounts of power. It is six with two cables having one connector and the other two have two.
Optical Drive Poll: https://linustechtips.com/main/topic/1006309-optical-drive-survey/
Main Rig (Pulsar)
CPU: Ryzen 7 5800X MOBO: MSI MEG X570 Unify RAM: Corsair Dominator Platinum RG(4x8gb) 3200Mhz 16-16-16-32 GPU: EVGA GTX 1080 FTW ACX 3.0 Cooler: Noctua NH-U12S Chromax (LTT Edition) Storage: Intel 6000p 128gb boot drive, Intel 665p 1tb (x2), Samsung 850 EVO 1tb, Case: Phanteks Enthoo Pro M Tempered Glass PSU: EVGA SupeNOVA G1+ 750W OS: Windows 10 Pro 64 bit
FreeNAS Server (The Vault)
CPU: Xeon E5-2603 v3 MOBO: MSI X99 Tomahawk RAM: G.Skill Aegis (4x8gb) 3000Mhz 16-18-18-38 GPU: EVGA GT 710 Cooler: Cooler Master Hyper 212 LED Storage: Intel S3520 x2 for boot, x16 in RAIDZ for storage, Seagate Ironwolf 2tb (Striped will be a steam cache) Case: Phanteks Enthoo Pro Tempered Glass PSU: Corsair CX750 750W
eps cable has 4 pairs of 12v wires.... good for 7a x 4 x 12v = 336w (according to ATX standard - the connectors can handle 9A, or 432w)
each 6+2 connector has 3 pairs of 12v+ground, the extra 2 pins are ground ....i suspect they reuse 2 pairs of wires on both connectors, and use one of each remaining pairs on the psu connector as the 3rd pair.
So if you plug both connectors on one cable into a video card, you have 56
6+2 connector 1 : 150w split across 3 pairs  = 50w per pair
6+2 connector 2 : 150w split across 3 pairs  = 50w per pair
at the psu end worst case scenario you'd have ...
pair 1 : 100w (50w from conn. 1, 50w from conn. 2)  -> 100w / 12v = 8.3a (technically safe)
pair2 : same , 100w
pair 3: 50w (one connector)
pair 4 : 50w (the other connector)
in real world the current will more of less even out between the pairs
pair2 : same , 100w
Yeah but the cable layout is not the same. You should not force an eps connector into a gpu or vice versa. They are keyed differently for a reason. Just because they can deliver the same wattage does not mean they can be used interchangeably. If you look at the image below you will see that the power and grounds are located in different spots which has the potential to cause big problems if you were to force them together
Main Rig (Pulsar)
Yes, they're different at the end where you plug into devices.
On the power supply end, the power supply manufacturer can use any connector they want, and any pinout they want.. there's no standard forcing them to make their cables compatible with other power supplies.
Here's a picture of what could be the wiring:
But why would you ever want to change that, you would still have something incorrectly keyed and have to force it in. The OP was not asking how many you could have if you mod the PSU, they asked how many PCIe power connectors there are. There are six total 6+2 pins (two singles two doubles) with two 4+4 pin eps
Main Rig (Pulsar)
No, it's not FORCED IN.
The connectors on the power supply DON'T HAVE TO BE EPS or PCI-E 8 PIN keyed.  They can be UNIVERSAL, without keys (holes in the connector shaped a certain way so you can't plug them in)
The connector on the power supply is 8 pins,  4 ground, 4 12v ... it doesn't CARE that the cable actually has EPS at the other end, or has pci-e 8pin at the other end.  It can be a generic 2 x 4 pin connector.
It simply gives 12v through those wires.
