Hey guys, need some help choosing a new monitor! it's time i got a new monitor, been using this for around about 6 years, it's some old BenQ 1920x1080@120hz with a few dead pixels. I'm so out of the loop with monitors! I don't know if i should get a 1440p monitor@144hz or get a 1080p@240hz? I do play a bit of competitive gaming "overwatch ect" but i do tend to have it on low settings to not have as much input lag. I do turn my settings to max when i am playing story/rpg games. My current build has a RTX 2080s and a i7 8700k@4.7
https://linustechtips.com/topic/1125760-monitor-suggestions/
1440p 144hz. I use one except mine is curved and has HDR. You're build it more than enough to max out the games at that resolution. Cause I can and have no where near those parts.
First watercooled System
Build Name: White Knight
OS: Windows 11 Pro 64-bit
Monitor: Alienware AW3423DWF 1800R Curved Ultrawide 3440x1440 QD-OLED 157hz 10 bit 0.1ms
Chassis: Lian Li 011 Dynamic EVO w/ 2x120mm Corsair QL RGB Fans on the bottom 1x120mm on back exhaust
Top Rad & Fans:  Corsair 54mm 360mm w/ 3x120mm Corsair ML Pro RGB Fans
Side Rad & Fans: Corsair 30mm 360mm w/ 3x120mm Corsair QL RGB Fans
Motherboard: Asrock X670E Steel Legend
CPU: AMD Ryzen 7 7800X3D w/ Corsair XC7 RGB Pro w/ Kyrosheet
Memory/RAM: Corsair Dominator RGB DDR5 2x16GB 32GB 6000Mhz
GPU: Asus GeForce RTX 4080 TUF w/ EK-Quantum Vector2 Nickel/Plexi & Backplate
Pump/Reservoir: Corsair XD5 RGB
Coolant: Corsair Clear
PSU: Lian Li Edge 1000W
Boot/OS SSD: Samsung 970 EVO Plus 500GB NVMe
WZ/2042 SSD: Samsung 850 EVO 250GB
Game SSD: Samsung 980 Pro 1TB
Performance/Editing HDD: Western Digital Black 1TB
Storage HDD: Western Digital Blue 1TB
Mouse: Razer Lancehead Tournament Edition/Razer Mamba
Mouse Mat: Corsair MM700 RGB
Keyboard: Razer Ornata Chroma
Microphone: HyperX Quadcast
Headset: Razer Blackshark v2 Pro
Eyewear/Glasses: Gunnar Optiks Razer FPS
Camera: Razer Kiyo Pro
https://linustechtips.com/topic/1125760-monitor-suggestions/#findComment-13062794
xb271hu
CPU i7 6700k MB  MSI Z170A Pro Carbon GPU Zotac GTX980Ti amp!extreme RAM 16GB DDR4 Corsair Vengeance 3k CASE Corsair 760T PSU Corsair RM750i MOUSE Logitech G9x KB Logitech G910 HS Sennheiser GSP 500 SC Asus Xonar 7.1 MONITOR Acer Predator xb270hu Storage 1x1TB + 2x500GB Samsung 7200U/m - 2x500GB SSD Samsung 850EVO
https://linustechtips.com/topic/1125760-monitor-suggestions/#findComment-13062813
Alright man, was just worried about input lag because everyone in the competitive scene just run 1080p. Do you recommend any monitors? Nothing stupidly expensive and 1ms response time.
https://linustechtips.com/topic/1125760-monitor-suggestions/#findComment-13062836
I'm not sure if any have a real 1ms response time. A lot of them say they do but then really its 4ms.
The model (Dell) in my signature is pretty nice.
Others I've had tried are:
AOC CQ32G1
Asus ROG Strix XG32VQ
Acer predator model I never had but I hear there pretty great as well.
https://linustechtips.com/topic/1125760-monitor-suggestions/#findComment-13062851
AOC CQ32G1
Thanks man, was looking at some Acer and AOC ones, just gonna keep my eye out for black Friday ? thanks again for your help!
https://linustechtips.com/topic/1125760-monitor-suggestions/#findComment-13062886
I picked this monitor up, if you are in America its a great option (GFT27DB). 1440p and 144hz, for a really reasonable price. Stand that comes with it does suck, but it does offer VESA compatibility. I love the picture that comes out of it, and now at 1440p and 144 hz I will not go back to gaming on a 1080 or sub 120 hz panel.
Its on sale too from what I paid for it. I have had G-Sync turned on for over a month and no issues thus far. A buddy of mine has it as well, and we both love the hell out of it. Look up this review of it.
My First (Current) Build:
Ryzen 7 2700 (3.90 1.35v OC) | Asus Prime X470 Pro | G.Skill Ripjaws V 16gb 3200 | Inland Professional 512gb M.2 NVME | Samsung 860 Evo Sata M.2 1TB | Corsair H115i Platinum | Corsair ML 140 RGB Fans | Fractal Design Meshify C | EVGA RTX 2070 XC Ultra
Laptop:
HP Spectre X360 13t Gem Cut (i7 8565u, 240gb, 8gb mem)
My Ride:
2015 VW Golf TDI Sportwagen
Eventually an XJ manual...
https://linustechtips.com/topic/1125760-monitor-suggestions/#findComment-13063023
Hey man, unfortunately I'm in the UK, that price is nice tho
https://linustechtips.com/topic/1125760-monitor-suggestions/#findComment-13063998
