I have an AMD R9 380 Graphics Card and its 3 years old, for about a year now whenever I run a game or video streaming it gets as hot as 96 Degree's. To try and fix it, I have implemented a fan curve but its no use; so my fan is always running at 100%.
Specs:
i5 - 6400
AMD R9 380 4gb
8gb Ram 2400mhz
Stock Cooler
(I don't know if its important but my computer was build in a inverted layout, so my PSU is above my GPU)
Message if you need any additional infomation.
Original PC: https://www.johnlewis.com/hp-omen-870-095na-desktop-pc-intel-core-i5-8gb-ram-1tb-128gb-ssd-amd-radeon-r9-gunmetal/p3100809
https://linustechtips.com/topic/1125637-r9-380-overheating-90-degrees/
these cards are old, you ought to try fresh thermal paste
Primary PC:
Specs:
i5 - 6400
AMD R9 380 4gb
8gb Ram 2400mhz
Stock Cooler
Maybe unrelated, but why does it say radeon R9 200 Series though?
AMD Ryzen R9 5900X  | Arctic Liquid Freezer II 360  |  GIGABYTE X570S AERO G  |  2x32GB G'skill TridentZ 4000MHz  | MSI RX 6900 XT Gaming Z Trio 16GB Dark Base Pro 900 (Orange)  | TOSHIBA 4TB 3.5" Drive - Game Drive | KINGSTON SNVS1000G 1TB M.2 NVME SSD - Boot Drive | FSP Hydro PTM PRO 1000W |
Living Room PC: AMD Ryzen 2400G | MSI RX VEGA 56 8GB AERO | 2x8 GB Crucial Ballistix 2400MHz | Intenso 250GB SSD | Seagate 500 GB HDD | Node 202 + 850W PSU |
Edgar,
After a driver update about a year ago it changed it across my entire system. Even on radeon settings it says R9 200 series after a double checked from where a bought the computer and it says R9 380. I also checked to see what it looked like in my case and I can tell you that it's a 380 not part of the 200 series.
Try updating drivers, and probably new thermal paste too. Depending on the quality of the paste it can dry out or reduce in performance. Does it throttle at all
Optical Drive Poll: https://linustechtips.com/main/topic/1006309-optical-drive-survey/
Main Rig (Pulsar)
CPU: Ryzen 7 5800X MOBO: MSI MEG X570 Unify RAM: Corsair Dominator Platinum RG(4x8gb) 3200Mhz 16-16-16-32 GPU: EVGA GTX 1080 FTW ACX 3.0 Cooler: Noctua NH-U12S Chromax (LTT Edition) Storage: Intel 6000p 128gb boot drive, Intel 665p 1tb (x2), Samsung 850 EVO 1tb, Case: Phanteks Enthoo Pro M Tempered Glass PSU: EVGA SupeNOVA G1+ 750W OS: Windows 10 Pro 64 bit
FreeNAS Server (The Vault)
CPU: Xeon E5-2603 v3 MOBO: MSI X99 Tomahawk RAM: G.Skill Aegis (4x8gb) 3000Mhz 16-18-18-38 GPU: EVGA GT 710 Cooler: Cooler Master Hyper 212 LED Storage: Intel S3520 x2 for boot, x16 in RAIDZ for storage, Seagate Ironwolf 2tb (Striped will be a steam cache) Case: Phanteks Enthoo Pro Tempered Glass PSU: Corsair CX750 750W
On 11/20/2019 at 8:04 PM, dannyj6185 said:
AdvancedMicroDustcollector
Fixed that for you!!!
Glad you got it working again though!
-Scott Manley, 2021
Softwares used:
Corsair Link (Anime Edition)
MSI Afterburner
OpenRGB
Lively Wallpaper
OBS Studio
Shutter Encoder
Avidemux
FSResizer
Audacity
VLC
WMP
GIMP
HWiNFO64
Paint
3D Paint
GitHub Desktop
Superposition
Prime95
Aida64
GPUZ
CPUZ
Generic Logviewer
