With keeping cables to a minimum is there a way of getting multi high speed USB's to a location on the desk?
I intend a front panel with the USB ports plus a on off switch plus a card reader going to USB header on board.
I want an Anker 10 but it plugs into USB on IO panel of mobo and has a power brick, neither of which i want...
Any advise??
https://linustechtips.com/topic/1125335-usb-hub-into-motherboard/
AMD blackout rig
cpu: ryzen 5 3600 @4.4ghz @1.35v
gpu: rx5700xt 2200mhz
ram: vengeance lpx c15 3200mhz
mobo: gigabyte b550 auros pro
psu: cooler master mwe 650w
case: masterbox mbx520
fans:Noctua industrial 3000rpm x6
Any advise??
or maybe this would work better less ports but no power brick
https://www.amazon.com/gp/slredirect/picassoRedirect.html/ref=pa_sp_atf_electronics_sr_pg1_2?ie=UTF8&adId=A0564299PDT8QZET3T3S&url=%2FExtension-Splitter-Multiple-Interfaces-Lightweight%2Fdp%2FB077D1FGZC%2Fref%3Dsr_1_2_sspa%3Fkeywords%3Dusb%2Bdata%2Btransfer%2Bexpansion%26qid%3D1574192662%26s%3Delectronics%26sr%3D1-2-spons%26psc%3D1&qualifier=1574192662&id=4220433358366728&widgetName=sp_atf
AMD blackout rig
Only some workstation based motherboard will have a external USB header directly on the motherboard. What you need to look are are 2.5" or 3.5" USB hubs those may have regular USB headers.
Intel Xeon E5 1650 v3 @ 3.5GHz 6C:12T / CM212 Evo / Asus X99 Deluxe / 16GB (4x4GB) DDR4 3000 Trident-Z / Samsung 850 Pro 256GB / Intel 335 240GB / WD Red 2 & 3TB / Antec 850w / RTX 2070 / Win10 Pro x64
HP Envy X360 15: Intel Core i5 8250U @ 1.6GHz 4C:8T / 8GB DDR4 / Intel UHD620 + Nvidia GeForce MX150 4GB / Intel 120GB SSD / Win10 Pro x64
HP Envy x360 BP series Intel 8th gen
AMD ThreadRipper 2!
5820K & 6800K 3-way SLI mobo support list
depending on the amount of power going to the hub (most likely either a 12v or 5v from a power brick), you could splice it into your psu directly and use this on the inside: https://www.amazon.com/Cablecc-Degree-angled-Motherboard-Header/dp/B06Y4NKRPF/
edit:
there are also things like this:
https://www.amazon.com/Kingwin-KW525-3U3CR-Multi-Function-Transfer-Bandwidth/dp/B01AJTOLRY/ref=sr_1_3?crid=20764JSQTVCE2&keywords=5%2B1%2F4%2Busb%2B3.0%2Bfront%2Bpanel&qid=1574194237&sprefix=usb%2B3.0%2B5%2B1%2F4%2Celectronics%2C131&sr=8-3&th=1
Plug it into the back of the motherboard instead of front panel IO?
