Fixing broken monitor
Go to solution Solved by VIVO-US,
Sorry, damage like this is impossible to fix. :(
The glass inside of the panel is cracked, which has in turn damaged the fine electronic traces going to each pixel.  Even the factory that made it wouldn't be able to fix it at this point.
https://linustechtips.com/topic/1125248-fixing-broken-monitor/#findComment-13059508
8 hours ago, Bizzare said:
So..my monitor broke today, and I don't have 300 usd to replace it. Is there anyway i can fix this on my own?
Almost anything can be fixed but, this is may not be worth it. You can try some PC or TV repair shops to see if it can be fixed, also, sometimes they have used or refurbished monitors in stock which may help save some ca$h.
Gaming With a 4:3 CRT
System specs below
CPU: AMD Ryzen 7 5700X with a Noctua NH-U9S cooler
Motherboard: Gigabyte B450 Aorus M (Because it was cheap)
RAM: 32GB (4 x 8GB) Corsair Vengance LPX 3200Mhz CL16
GPU: EVGA GTX 980 Ti SC Blower Card
HDD: 7200RPM TOSHIBA DT01ACA100 1TB, External HDD: 5400RPM 2TB WD My Passport
SSD: 1tb Samsung 970 evo m.2 nvme
PSU: Corsair CX650M
Displays: ViewSonic VA2012WB LCD 1680x1050p @ 75Hz
Gateway VX920 CRT: 1920x1440@65Hz, 1600x1200@75Hz, 1200x900@100Hz, 960x720@125Hz
Gateway VX900 CRT: 1920x1440@64Hz, 1600x1200@75Hz, 1200x900@100Hz, 960x720@120Hz (Can be pushed to 175Hz)
Keyboard: Thermaltake eSPORTS MEKA PRO with Cherry MX Red switches
https://linustechtips.com/topic/1125248-fixing-broken-monitor/#findComment-13059824
