My laptop heats up when...I'm not using it?
I've noticed that, when I'm actively using my laptop, opening Chrome tabs or whatever, my laptop can stay completely quiet with no fans on for hours.
But oddly enough, when I let it open, with the screen on, but I'm doing nothing on it for a few minutes, it goes crazy, it starts to heat up and the fans turn on.
How come NOT using my laptop somehow makes it heat up more than using it?
https://linustechtips.com/topic/1124984-my-laptop-heats-up-whenim-not-using-it/
It's probably background processes that wait for the computer to be idle.  There may be Windows updates installing, or an anti-virus program might be doing background scans.
If you want to find out for sure, set the screensaver and turning screen off to "never".  Bring up the task manager, set it to always sort by highest CPU usage, and then see what's happening once the computer is "idle".
Mine does this too. Afaik, this is caused by Windows doing clean up stuff when your computer has been idle for some time.
Small tiny tiny possibility you’ve been botnetted and someone is trying to mine bitcoin with your box or something.  There are much more reasonable and likely answers already posted though.
Background processes, The simple act of waking up from sleep sends the CPU straight to 100% usage (R5 2500U here so wouldnt doubt thats happening to you) and thus fans start spinning hard on wake
Primary Laptop (Gearsy MK4): Ryzen 9 5900HX, Radeon RX 6800M, Radeon Vega 8 Mobile, 24 GB DDR4 2400 Mhz, 512 GB SSD+1TB SSD, 15.6 in 300 Hz IPS display
2021 Asus ROG Strix G15 Advantage Edition
Secondary Laptop (Uni MK2): Ryzen 7 5800HS, Nvidia GTX 1650, Radeon Vega 8 Mobile, 16 GB DDR4 3200 Mhz, 512 GB SSD
2021 Asus ROG Zephyrus G14
Meme Machine (Uni MK1): Shintel Core i5 7200U, Nvidia GT 940MX, 24 GB DDR4 2133 Mhz, 256 GB SSD+500GB HDD, 15.6 in TN Display
2016 Acer Aspire E5 575
Retired Laptop (Gearsy MK2): Ryzen 5 2500U, Radeon Vega 8 Mobile, 12 GB 2400 Mhz DDR4, 256 GB NVME SSD, 15.6" 1080p IPS Touchscreen
2017 HP Envy X360 15z (Ryzen)
PC (Gearsy): A6 3650, HD 6530D , 8 GB 1600 Mhz Kingston DDR3, Some Random Mobo Lol, EVGA 450W BT PSU, Stock Cooler, 128 GB Kingston SSD, 1 TB WD Blue 7200 RPM
HP P7 1234 (Yes It's Actually Called That)  RIP
Also im happy to answer any Ryzen Mobile questions if anyone is interested!
