ok so will a 5700XT work on pcie 3.0?
Solved by vanished,
Just now, xreaperx22 said:ok so next question would the 5700XT be a significant upgrade over the 980TI im using now? a lot of people are trying to get me to go with a 2070 super instead but price per performance cant be beat with the 5700XT to me.
I don't have an exact test to show you but I would estimate that the 5700 XT would be roughly a 50% uplift over the 980 Ti, though this will vary by game and I would say that answer is at best +/-10%. As for value vs the Super series, you are correct, the 5700 XT is a better value unless you need the nvidia specific features like NVENC encoder, RTX, etc. or want to exceed that performance level (2080+).
