[Build Log] Lucid Vision ft. 5700XT Liquid Devil (My First Custom Loop)
Recommended
Completed!
Glad I was able to keeping as visually similar as possible.
Changes:
Replaced the 3900X with a 3950X.
Replaced the EKWB PE CoolStream 360 radiator with an XEm going from 38mm wide to 60mm wide. Did I need the extra capacity? I have no idea.
Replaced the 32GB Corsair Vengeance RGB Pro with 64GB 3600 CL16 Trident-Z Neo.
Installed an Asus XG-C100C PCIe x4 10 Gbit/s Network Adapter... probably should have done this the first go around, bu
I recommend this, because science. -TV
Recommended by TVwazhere
