Capture Card Sound Hiccups
Solved by ZeldaN64,
So I figured out THIS problem as well.
As it turns out the little booklet that comes with the capture card recommends "Output desktop audio (WaveOut)" so I changed it to (Direct sound) and now there is no more hiccups, though I think the tone is still deeper, but that's not a big problem, in my opinion.
2
5
2
1
11
SpitfiremkII ·
Posted in Displays3 -
8
Master_Failure ·
Posted in General Discussion0 -
Zoikollo ·
Posted in New Builds and Planning4
