10 minutes ago, JubaSniper said:
Right now im using the H115i from Corsiar to cool the CPU plus i just recently installed 4 case fans with plans adding 2 more but i feel like my CPU its still too hot at 47°C on light workloads
Depending what "light workloads" mean, 47°C could be low.
What temperature does the CPU reach under heavier loads, such as while gaming?
Which fans do you use?
What is the ambient temperature?
Overall, 47˚C isn't that bad on a small workload. In fact it's pretty good.
How high does it go if you push it harder, like rendering something or with prime95?
You'll never get sub or equal to ambient temperature with air or water cooling.
CPU: AMD Ryzen 3700x / GPU: Asus Radeon RX 6750XT OC 12GB / RAM: Corsair Vengeance LPX 2x8GB DDR4-3200
MOBO: MSI B450m Gaming Plus / NVME: Corsair MP510 240GB / Case: TT Core v21 / PSU: Seasonic 750W / OS: Win 11 Pro
What is said above is correct. We really need to know what the max temp is under load to be able to give advice.
There is always a huge push to try and throw fans in the case and make things run as cool as humanly possible... But really, the main benefit from water cooling is to get temps under control, but doing it without being obscenely loud. Assuming the radiator is an exhaust, you're removing all of the CPU's heat out of the case which cools everything else off as well.
Anyways, let us know what the max temps are and we can help you further. If they are sub 80c in a load like prime95, I would argue your current setup is plenty sufficient since that sort of load is not "normal". My 8700k hits low 80's in prime95, but only hits mid 60's in a game... If you do rendering often, spin up a render and check the temps, if they are under 75c, you're more than fine.
Rig: i7 13700k - - Asus Z790-P Wifi - - RTX 4080 - - 4x16GB 6000MHz - - Samsung 990 Pro 2TB NVMe Boot + Main Programs - - Assorted SATA SSD's for Photo Work - - Corsair RM850x - - Sound BlasterX EA-5 - - Corsair XC8 JTC Edition - - Corsair GPU Full Cover GPU Block - - XT45 X-Flow 420 + UT60 280 rads - - EK XRES RGB PWM - - Fractal Define S2 - - DellAlienware AW3423DWF 34" -- Logitech G502 - - Logitech G710+ - - Logitech Z5500 - - LTT Northern Lights Deskpad
Headphones/amp/dac: Schiit Lyr 3 - - Fostex TR-X00 - - Sennheiser HD 6xx
Homelab/ Media Server: Proxmox VE host - - 512 NVMe Samsung 980 RAID Z1 for VM's/Proxmox boot - - Xeon e5 2660 V4- - Supermicro X10SRF-i - - 128 GB ECC 2133 - - 7x14TB Ultrastar RAID Z2 - - 45 HomeLab HL15 15 Drive 4U - - Corsair RM650i - - LSI 9305-16i HBA - - TreuNAS + many other VM’s
iPhone 14 Pro - MacBook Air M3
If you want powerful fans get these. https://www.amazon.com/Noctua-NF-F12-iPPC-3000-PWM/dp/B00KFCRATC
Or these  https://www.amazon.com/Noctua-Bearing-NF-A14-iPPC-3000-PWM/dp/B00KFCRF1A/ref=pd_sbs_147_img_2/141-6683204-2960252?_encoding=UTF8&pd_rd_i=B00KFCRF1A&pd_rd_r=238ae6c6-8e91-4bda-bb19-2ffde9a7eccb&pd_rd_w=0sTeP&pd_rd_wg=Ftgz9&pf_rd_p=5cfcfe89-300f-47d2-b1ad-a4e27203a02a&pf_rd_r=MWYV9RD0YJP2XB2T4Z7A&psc=1&refRID=MWYV9RD0YJP2XB2T4Z7A
  • My system specs
  • View 91 Tempered Glass RGB Edition, No PSU, XL-ATX, Black, Full Tower Case
  • ROG MAXIMUS XI EXTREME, Intel Z390 Chipset, LGA 1151, HDMI, E-ATX Motherboard
  • Core™ i9-9900K 8-Core 3.6 - 5.0GHz Turbo, LGA 1151, 95W TDP, Processor
  • GeForce RTX™ 2080 Ti OC ROG-STRIX-RTX2080TI-O11G-GAMING, 1350 - 1665MHz, 11GB GDDR6, Graphics Card
  • ROG RYUJIN 360, 360mm Radiator, Liquid Cooling System
  • 32GB Kit (2 x 16GB) Trident Z DDR4 3200MHz, CL14, Silver-Red DIMM Memory
  • AX1600i Digital, 80 PLUS Titanium 1600W, Fanless Mode, Fully Modular, ATX Power Supply
  • Formula 7, 4g, 8.3 (W/m-K), Nano Diamond, Thermal Compound
  • On AIO cooler 6 x NF-F12 IPPC 3000 PWM 120x120x25mm 4Pin Fibre-glass SSO2 Heptaperf Retail
  • 6 x NF-A14 IPPC-3000 PWM 140mm, 3000 RPM, 158.5 CFM, 41.3 dBA, Cooling Fan
  • 1TB 970 PRO 2280, 3500 / 2700 MB/s, V-NAND 2-bit MLC, PCIe 3.0 x4 NVMe, M.2 SSD
  • Windows 10 Pro 64-bit
  • Beyerdynamic MMX 300 (2nd Generation) Premium Gaming Headset
  • ROG PG279Q
  • Corsair K95 Platinum XT
  • ROG Sica
They're the 140mm fans that came with the pump. I want to switch them for the RGB fans sooner or later but dont know if its gonna put stress on it. Ambient temp is around 43°c but say now like im playing Modern Warfare it gets to the 60s
Loght workloads could be bad terminology because its basically just watching YouTube having multiple tabs open etc. When i play games like Modern Warfare for example it hits 60°c+ easily and im just not trying to have to fry my motherboard cause i also have the MEG Godlike and im not trying to buy another ?
60°C is pretty good for a 9900K under load. Nothing to worry about.
Do you mean the ambient temp in the room / area with the computer is 43°C?  That's a bit warm - about 109.4°F for the Americans / USA residents among the LTT community. ??
I think the hottest it's been at my house was probably around 100-104°F / 37.78-40°C, and that only once maybe 15 or 20 years ago, otherwise it rarely hits 90°F / 32.2°C indoors, maybe once or twice a year.   (We do get upwards of 83-86°F / 28.33-30°C quite often in summer though.)  My cousin a few miles west of me (she's in La Mesa, CA - east of San Diego) has seen 104°F / 40°C in summer in her house.
Maybe you live in the desert?  I could imagine indoor temperatures near 110°F or higher would be possible in places like Phoenix, Palm Springs, Vegas, or other desert areas like north Africa or parts of Australia, in a house with poor insulation and no air conditioning. :)
Lol no the room is so random it could be freezing maybe 60 but then ill just be cooking ? like high 80s. With it being 30°F outside its hard to keep a room and a constant temp apparently. But im saying the PCs temp just sitting is low 40°C
