Record it externally with a phone or something.
Quote me to see my reply!
SPECS:
CPU: Ryzen 7 3700X Motherboard: MSI B450-A Pro Max RAM: 32GB I forget GPU: MSI Vega 56 Storage: 256GB NVMe boot, 512GB Samsung 850 Pro, 1TB WD Blue SSD, 1TB WD Blue HDD PSU: Inwin P85 850w Case: Fractal Design Define C Cooling: Stock for CPU, be quiet! case fans, Morpheus Vega w/ be quiet! Pure Wings 2 for GPU Monitor: 3x Thinkvision P24Q on a Steelcase Eyesite triple monitor stand Mouse: Logitech MX Master 3 Keyboard: Focus FK-9000 (heavily modded) Mousepad: Aliexpress cat special Headphones:  Sennheiser HD598SE and Sony Linkbuds
16 minutes ago, Sygress said:
I have had this problem for months now and i want it fixed.
Talk to Rockstar about how they render their shadows then. It's not something you can fix.
CPURyzen 7 5800X with Arctic Liquid Freezer II 120mm AIO & push-pull Arctic P12 PWM fans RAM: G.Skill Ripjaws V 4x8GB 3600 16-16-16-30
PSU: Be Quiet! Pure Power 12 M 1000W GPUASRock RX 5700 XT Reference with Eiswolf GPX-Pro 240 AIO & 2x Arctic P12 PWM fans Case: Antec P5
MotherboardASRock X570M Pro4 Monitor: ASUS ROG Strix XG32VC Storage: HP EX950 1TB NVMe, Mushkin Pilot-E 1TB NVMe, 2x Constellation ES 2TB in RAID1
https://hwbot.org/submission/4497882_btgbullseye_gpupi_v3.3___32b_radeon_rx_5700_xt_13min_37sec_848ms
7 minutes ago, Sygress said:
@kevinhall05 uh okay looks the same as the recording
I dont see any purple in the recording so it may be something related to the monitor or output so his point is valid. Record it with a phone which takes any internal bypasses and other random internal stuff out of the equation
GUITAR BUILD LOG FROM SCRATCH OUT OF APPLEWOOD
- Ryzen Build -
R5 3600 | MSI X470 Gaming Plus MAX | 16GB CL16 3200MHz Corsair LPX | Dark Rock 4
MSI 2060 Super Gaming X
1TB Intel 660p | 250GB Kingston A2000 | 1TB Seagate Barracuda | 2TB WD Blue
be quiet! Silent Base 601 | be quiet! Straight Power 550W CM
2x Dell UP2516D
- First System (Retired) -
Intel Xeon 1231v3 | 16GB Crucial Ballistix Sport Dual Channel | Gigabyte H97 D3H | Gigabyte GTX 970 Gaming G1 | 525 GB Crucial MX 300 | 1 TB + 2 TB Seagate HDD
be quiet! 500W Straight Power E10 CM | be quiet! Silent Base 800 with stock fans | be quiet! Dark Rock Advanced C1 | 2x Dell UP2516D
Reviews: be quiet! Silent Base 800 | MSI GTX 950 OC
