Hello,
I have ASUS H87-PRO and am trying to boot with i7-4790.
Yea,
I surely updated the bios with the most recent one (2104), but never boots up.
It works fine with i5-4570 but NO luck with i7-4790.
ASUS surely says this board is surely compatible with i7-4790 with bios version  newer than 1105.
Never worked out.
Very same case happens with ASUS H87-PLUS.
Would somebody help me what is wrong here updating the BIOS?
Thanks in avance.
OS: Windows 10 PRO (64bit)
CPU: i7-4790
Motherboard: ASUS H87-PRO (BIOS Ver:2104)
RAM: 4x 2Gb PC3-10600U
https://linustechtips.com/topic/1124615-asus-h87-pro-is-not-compatible-with-i7-4790/
Have you just got the 4790?
زندگی از چراغ
Intel Core i7 7800X 6C/12T (4.5GHz), Corsair H150i Pro RGB (360mm), Asus Prime X299-A, Corsair Vengeance LPX 32GB (4X4GB & 2X8GB 3000MHz DDR4), MSI GeForce GTX 1070 Gaming X 8G (2.113GHz core & 9.104GHz memory), 1 Samsung 970 Evo Plus 1TB NVMe M.2, 1 Samsung 850 Pro 256GB SSD, 1 Samsung 850 Evo 500GB SSD, 1 WD Red 1TB mechanical drive, Corsair RM750X 80+ Gold fully modular PSU, Corsair Obsidian 750D full tower case, Corsair Glaive RGB mouse, Corsair K70 RGB MK.2 (Cherry MX Red) keyboard, Asus VN247HA (1920x1080 60Hz 16:9), Audio Technica ATH-M20x headphones & Windows 10 Home 64 bit.
The time Linus replied to me on one of my threads:
I think ASUS does NOT put CPU micro-code for i7-4790 to the BIOS file.
Otherwise something is very wrong with BIOS updater file.
Tested the i7-4790 with H97 PRO, and verified working flawlessly.
Very much disappointing to ASUS service..
Oh I can fix this one! I've been through this very same thing and it took me MONTHS to figure out so now you don't have to.
It's an issue with the BIOS update utility not actually applying the update, tldr use the Windows based update utility.
