Noise cancelling headphones eliminate PC fan noise?
Title, and also air conditioning fan noise and etc fans too?? I also get mild highway traffic in my room
Edit: And if I were to go down this route, what headphones should I pick up?
Extra edit :
1. Budget? $500, although if it's worth the extra $ do pitch it to me
2. Type? So: On/Over/In Ear? On/Over, I'm guessing On Ear is better for noise cancellation?
3. Whats more important to you Sound VS ease of use/comfortability  Sound 100x
4. For mobile usage: I'm on iOS
I like bass, really do. Would prefer a good soundstage and clarity too
My Sennheiser and my AirPods Pro both do a near perfect job at this!
To recommend something we need to know:
1. Budget?
4. For mobile usage: iOS or Android user?
FOLDING MONTH 2021! GOGOGO and save on some heating costs 🙂
I like bass, really do. Would prefer a good soundstage and clarity too.
Which model are your Sennheisers?
THX for the info bro!
Over ear is the best for ANC. But I am surprised every time how good my AirPods Pro do the ANC ?
I have Sennheiser https://en-us.sennheiser.com/momentumwireless
Best Sound in class, but Bose has a bit better ANC. Though Boses sound is pretty muddy compared to sennheiser wich is very clear but good bass powahhh :D. Therefore Idd recommend the Momentum wireless
AirPods pro are super comfortable and work like a charm with  devices but the sound is pretty shit in comparison with the Senns
