Didn't do good enough research on the MSI RX580. I'm running Modern Warfare at 60 fps, with settings practically on medium. I am running in the 69-71 C degrees. I know that's not terrible, but I believe I can get better texture, and "range" settings if I could cool this mother down. It shoots to 75+ C with almost any other settings adjusted. ++ I updated the cooling in my Corsair 100r case and have good airflow as well.
Are there any CPU cooling fan kits to fit on this bad boy, or should I sell this baby for like new and add some doll hairs to fork out for the 5700 XT?
Anything helps!
"Soli Deo Gloria"
IT Technician by trade. Computer/Network equipment enthusiast!
Gaming PC:
  • AMD Ryzen 5 2600X (Stock Core Clock)
  • XFX RX 590 FATBOY 8 GB (Stock Core Clock)
  • Asus ROG Strix B450-F Motherboard
  • Crucial Ballistix 16 GB (2x8) kit 3200 Mhz RAM
  • 512 GB Intel 660p M.2 NVMe SSD (Boot & Current Games)
  • 3 TB Toshiba HDD @ 7,200 rpm (Data)
  • 2 TB Seagate HDD @ 7,200 rpm (Backup)
  • Corsair CX650M PSU
  • NZXT S340 Elite Case
  • 24" AOC C24G1 1500r Curved Gaming Monitor 144hz 1080p
  • Turtle Beach Stealth 450 Gaming Headset
  • Corsair K63 10-Keyless Mechanical Gaming Keyboard (Cherry MX)
  • Logitech G602 Wireless Gaming Mouse, Razor Death Adder
  • Win10 Home
PC Part Picker Link
https://linustechtips.com/topic/1124083-msi-rx580-armour-cooling-issues/
75 is fine. Anything above ~84 is something to start worrying about.
I think if you crank up settings without doing any OC it might not even get hotter,  it's like that on my MSI 1060 gaming x in some games,  the fans will just spin faster.
Also while 75C is definitely fine,  yes there are coolers,  air or liquid...  Requires a lot of tinkering from what I'm seeing though.
PS: I think these kind of threads purpose is almost always to justify buying new PC parts,  so go for it I say, a 5700xt should about double your performance.  ?
(and probably not run any cooler lol)
PSS: I had your exact same card to replace a 1050ti,  it ran very hot and performance was piss poor,  I think something was broken probably but idk.  Could have been poor airflow also,  but both my 1050ti and 1060 run a lot cooler in the same case...
-Scott Manley, 2021
Softwares used:
Corsair Link (Anime Edition)
MSI Afterburner
OpenRGB
Lively Wallpaper
OBS Studio
Shutter Encoder
Avidemux
FSResizer
Audacity
VLC
WMP
GIMP
HWiNFO64
Paint
3D Paint
GitHub Desktop
Superposition
Prime95
Aida64
GPUZ
CPUZ
Generic Logviewer
Thermal paste? MSI armor cards on 10 series and RX 400/500 series are known for being weak so there's not a lot else you could do to fix it while being reasonable.
Desktop benching:
