Hi. I'm currently running a Ram configuration of 4x4GB Corsair Vengeance LPX DDR4 at 3000mHz and I was wondering if I can replace 2/4 modules with a pair of higher speed 2x8GB Corsair Vengeance RGB Pro DDR4 @ 3200mHz. My main concern is even will I be able to run the 2 pairs of Ram in dual channel in 2 different speed (3000 with 3000, 3200 with 3200) since AMD doesn't support quad channel anyway.
Here's my full spec list if it can help. ASRock B450M Pro4, Ryzen 7 2700x + Wraith Prism Cooler, 4x4GB Corsair Vengeance LPX DDR4 @ 3000mHz, Thermaltake SMART 500W and Gigabyte G1 Gaming 1070 Rev 1.0
Thank you for your help.
Yes Im running 2x 3600mhz 8gb sticks from Vcolor and 2x 2133mhz 8gb sticks from Patriot one set downclocked to 2666mhz, other OCd to 2666mhz both CL18 for certain tasks Im doing atm.  However mine are staggered and I have the same board, per the manual.
Workstation Laptop: Dell Precision 7540, Xeon E-2276M, 32gb DDR4, Quadro T2000 GPU, 4k display
Wifes Rig: ASRock B550m Riptide, Ryzen 5 5600X, Sapphire Nitro+ RX 6700 XT, 16gb (2x8) 3600mhz V-Color Skywalker RAM, ARESGAME AGS 850w PSU, 1tb WD Black SN750, 500gb Crucial m.2, DIYPC MA01-G case
My Rig: ASRock B450m Pro4, Ryzen 5 3600, ARESGAME River 5 CPU cooler, EVGA RTX 2060 KO, 16gb (2x8) 3600mhz TeamGroup T-Force RAM, ARESGAME AGV750w PSU, 1tb WD Black SN750 NVMe Win 10 boot drive, 3tb Hitachi 7200 RPM HDD, Fractal Design Focus G Mini custom painted.
NVIDIA GeForce RTX 2060 video card benchmark result - AMD Ryzen 5 3600,ASRock B450M Pro4 (3dmark.com)
Daughter 1 Rig: ASrock B450 Pro4, Ryzen 7 1700 @ 4.2ghz all core 1.4vCore, AMD R9 Fury X w/ Swiftech KOMODO waterblock, Custom Loop 2x240mm + 1x120mm radiators in push/pull 16gb (2x8) Patriot Viper CL14 2666mhz RAM, Corsair HX850 PSU, 250gb Samsun 960 EVO NVMe Win 10 boot drive, 500gb Samsung 840 EVO SSD, 512GB TeamGroup MP30 M.2 SATA III SSD, SuperTalent 512gb SATA III SSD, CoolerMaster HAF XM Case.
https://www.3dmark.com/3dm/37004594?
Daughter 2 Rig: ASUS B350-PRIME ATX, Ryzen 7 1700, Sapphire Nitro+ R9 Fury Tri-X, 16gb (2x8) 3200mhz V-Color Skywalker, ANTEC Earthwatts 750w PSU, MasterLiquid Lite 120 AIO cooler in Push/Pull config as rear exhaust, 250gb Samsung 850 Evo SSD, Patriot Burst 240gb SSD, Cougar MX330-X Case
May I ask what you need more than 16gb for? Im very rarely in need of this 32gb configuration I am using atm.
The main reason is probably because I found someone selling the 3200mhz kit for cheap on the marketplace so honestly this is a good opportunity to future-proof my machine a little bit for the years to come.
Also can I ask if you have to underclock and overclock the 2 pairs to the same speed or is there a particular reason for you to do so? Thanks.
they have to be the same timing and speed i believe, so that's why they are over and underclocked.
CPU: 5800x
GPU: 1070ti
HDD: Seagate 3TB
SSD: 1TB WD NVME
RAM: 32GB ddr4 3200
HEADPHONES: DT990 pro 250ohm limited edition black
MONITER: BenQ xl2536
CASE: s340 elite hyperbeast
KEYBOARD: nk87- zilent switches
MOUSE: G403 Hero
All the RAM in the system has to run at the same speed and timings, your motherboard wont even have an option to set them individually. So you may be able to overclock your current ones up to 3200Mhz C# otherwise you'll have to slightly down-clock the new ones. You would have to make sure that each 8GB dimm is in a different channel otherwise you'll be running in flex-mode.
Do you actually need the extra RAM though?
I see. Thank you for the clarification.
Ah that's a shame. If I were to buy tht kit this is just simply going into the bios and choose 3000 in the ram speed drop down menu right?
or typing it in, but it should be relatively simple
CPU: 5800x
GPU: 1070ti
HDD: Seagate 3TB
SSD: 1TB WD NVME
RAM: 32GB ddr4 3200
MOUSE: G403 Hero
To be honest probably not, just the price of 80 canadian pesos for a brand new kit of rgb rams is really tempting to me haha. Thank you so much for the explanation.
Thank you for the help. Really appreciate it.
