I have an i5 6400 and I used the stock cooler that came with it for 2 years with no problem.
But now I order an i5-9600kf and I know that it doesn't come with a stock cooler, but I don't really have money to buy one.
Can I use the stock Intel cooler that I have or do I need to get one? And If I do, what is a good option for cheap?
https://linustechtips.com/topic/1123808-stock-cooler-i5-9600kf/
no. the i5 6400 is a 65W tdp and the i5 9600KF is a 95w tdp. dont even think about overclocking lol
Im with the mentaility of "IF IM NOT SURE IF ITS ENOUGH COOLING, GO OVERKILL"
CURRENT PC SPECS
CPU             Ryzen 5 3600 (Formerly Ryzen 3 1200)
GPU             : ASUS RX 580 Dual OC (Formerly ASUS GTX 1060 but it got corroded for some odd reasons)
GPU COOOER      : ID Cooling Frostflow 120 VGA (Stock cooler overheats even when undervolted :()
MOBO            : MSI B350m Bazooka
MEMORY          Team Group Elite TUF DDR4 3600 Mhz CL 16
STORAGE         : Seagate Baracudda 1TB and Kingston SSD
PSU             : Thermaltake Lite power 550W (Gonna change soon as i dont trust this)
CASE            : Rakk Anyag Frost
CPU COOLER      : ID-Cooling SE 207
CASE FANS       : Mix of ID cooling fans, Corsair fans and Rakk Ounos (planned change to ID Cooling)
DISPLAY         : SpectrePro XTNS24 144hz Curved VA panel
MOUSE           : Logitech G603 Lightspeed
KEYBOARD        : Rakk Lam Ang
HEADSET         : Plantronics RIG 500HD
Kingston Hyper X Stinger
and a whole lot of LED everywhere(behind the monitor, behind the desk, behind the shelf of the PC mount and inside the case)
https://linustechtips.com/topic/1123808-stock-cooler-i5-9600kf/#findComment-13047799
Intel stock cooler is not that good, expecially when palying intensive games at 1080p and rendering, and you have skylake stock cooler which is little worse than intel bad ninth gen stock cooler. (im not amd fanboy, but intel's stock cooler are not good, it is just my opinion)
I Use my knowledge as business owner and self taught technician aswell as an AI to help people. AI might be controversial but it actually works pretty well 90% of the time.
https://linustechtips.com/topic/1123808-stock-cooler-i5-9600kf/#findComment-13047803
you can, its just not very recommended to do so.
would encourage to get something with hyperthreading from current gen, but if you have allready done the transaction im guessing its a bit late.
https://linustechtips.com/topic/1123808-stock-cooler-i5-9600kf/#findComment-13047805
Well I got it for 140€. And I can't afford an i7 at this point. Isn't this processor good at 1080p gaming?
https://linustechtips.com/topic/1123808-stock-cooler-i5-9600kf/#findComment-13047825
deepcool gammaxx 400 is one of the cheapest ones that dont suck. its equivalent of the coolermaster hyper 212 at about $20. There are cheaper options but im not sure what to recommend on those. they said the snowman and great wall is ok.
CURRENT PC SPECS
https://linustechtips.com/topic/1123808-stock-cooler-i5-9600kf/#findComment-13047830
there is allways the r5 2600, or maybe even 2700 if you are lucky.
you dont have to get core i7 CPUs.
https://linustechtips.com/topic/1123808-stock-cooler-i5-9600kf/#findComment-13047835
its good with the exception of a couple of increasing number of games.
not to really worry about if you have ordered it, just something to be aware of
https://linustechtips.com/topic/1123808-stock-cooler-i5-9600kf/#findComment-13047836
9 minutes ago, Rafaelos said:
So do you have any recommendations that are cheap?
Snowman T4 from AliExpress.
M.S.C.E. (M.Sc. Computer Engineering), IT specialist in a hospital, 32+ years of gaming, 20+ years of computer enthusiasm, Geek, Trekkie, anime fan
  • Peripherals: LG 32GK650F - Dell P2319h - Logitech G Pro X Superlight with Tiger Ice - Madlions MAD 68HE Pro - EndGame Gear MPC890 - Genius HF 1250B - Akliam PD4 - Sennheiser HD 560s - Tripowin Vivace - Simgot EM6L - Truthear Zero - QKZ x HBB - 7Hz Salnotes Zero - Logitech C270 - Behringer PS400 - BM700  - Colormunki Smile - Speedlink Torid - Jysk Stenderup - LG 24x External DVD writer - Konig smart card reader
  • Networking: Asus TUF Gaming AX6000 - Huawei OptiXstar EG8145X6-10 - 1000/500 Mbps fiber optic Internet access
  • TV and gadgets: TCL 50EP680 50" 4K LED + Sharp HT-SB100 75W RMS soundbar - Samsung Galaxy Tab A8 10.1" - OnePlus 13 16GB/512GB - OnePlus 9 256GB - Olymous Cameda C-160 - GameBoy Color - Miyoo A30 Spruce
  • Livingroom PC (dad uses): AMD FX 8300 - Arctic Freezer 64 - Asus M5A97 R2.0 Evo - 2x4 GB DDR3 1833 Kingston - MSI Radeon HD 7770 1GB OC - 120GB Adata SSD - 500W Fractal Design Essence - DVD-RW - Samsung SM 2253BW - Logitech G710+ - wireless vertical mouse - MS 2.0 speakers
https://linustechtips.com/topic/1123808-stock-cooler-i5-9600kf/#findComment-13047842
Is the 9600kf compatible with the asus b360m-a board?? I don't need oc
https://linustechtips.com/topic/1123808-stock-cooler-i5-9600kf/#findComment-13047851
It is, tho why get the 9600kf if you arent going to OC?
Just get the 9400f. Or even better, the 2600.
Both should go for about 120$ equivelent currency
https://linustechtips.com/topic/1123808-stock-cooler-i5-9600kf/#findComment-13047856
Well the 9600kf gets a little more fps even without oc than the 9400.And it is exactly the same price
https://linustechtips.com/topic/1123808-stock-cooler-i5-9600kf/#findComment-13047885
ah, fair enough.
the 9400f the same price or?
would still suggest 6c/12t since the r5 2600 is right around that pricepoint.
https://linustechtips.com/topic/1123808-stock-cooler-i5-9600kf/#findComment-13047906
What case and ram are you using?
Budget?
https://linustechtips.com/topic/1123808-stock-cooler-i5-9600kf/#findComment-13056658
Either snowman, or ID SE-214X the latter is 160mm tall though, so might not fit!
or even SE-213V2, though I'd undervolt the CPU just to be sure. But this little guy is still more capable, by far, than the stock intel cooler.
Life is really challenging. I don't always suceed: )
https://linustechtips.com/topic/1123808-stock-cooler-i5-9600kf/#findComment-13057654
the TPD is irrelevant.
nobody runs their CPU at the baseclock.
in AVX titles like BFV or the new need for speed your CPU can easily go above 120-130 watts.
my friend runs a 9600k at 5Ghz with a NH U12S and peaks at around 70°C.
that costs around 60 bucks and is inaudible and very high quality.
https://linustechtips.com/topic/1123808-stock-cooler-i5-9600kf/#findComment-13058244
