Help! +5V in bios constant at 6.9volts and 100 Celsius idle cpu temp!
Go to solution Solved by BearPan,
Best course of action after doing all those steps was to replace the motherboard and cpu
So, I’ve been at this for two days now, and I have no idea what else to do. For starters, I recently bought all these parts (pcpartpicker link to the build), and immediately noticed the voltage on the +5V in the bios was stuck at 6.9 volts. I honestly have no idea what I’m doing when it comes to more advanced mobo things, so I took to the internet; what was suggested was for me to check the psu, I changed this pc’s psu with my other pc, same result, reset the cpu, clean and reapply thermal paste to the cpu/heat sink, same result, change the battery on the mobo, same result, flash/update the bios, and I tried reapplying all the modular cables from the psu to their appropriate positions on the mobo. Nothing seems to fix it, by chance is it a faulty motherboard or a screwy cpu?
build:
CPU: amd ryzen 7 2700x
GPU: sapphire Radeon rx 5700
Mobo: Asus ROG b450-f gaming
Bios used to update/flash: Asus 2901
What about PSU?
UPD: Nevermind, didn't notice it...
Did you try changing your motherboard?
Purify your Windows 10/11, don't give Microsoft anything that you don't want to share.
https://drive.google.com/open?id=1ZwVs9zrM493rjD42E2Pf0YcOkaW92ZUo
Tips for folding on laptop:
Lazy man wants upgrades from the sky.
https://stats.foldingathome.org/donor/Spakes
