Ram Stick Doesn't fit, CPU Cooler in the way!
Everything is going well, part from the memory stick :(
I have installed corsair H115I that has 140mm fans on the top of the case into the phanteks enthoo pro case, the memory that I'm using "Here" doesn't fit in the sockets since there is not enough space between the fans and where the connections are on the board.
Thought about moving the cooler to the front but that also means re-cabling it and might not go so well. With the case that I have is there an option to put the fans or the heatsink on the otherside of the bar.
https://linustechtips.com/topic/1123632-ram-stick-doesnt-fit-cpu-cooler-in-the-way/
