Random fps drops even thought first half hour of session was god
In the middle of a session, my fortnite fps dropped from a solid 144hz constantly to around 100- 80 fps during the most random time. I have a rx 5700 and i am playing at 1080p and for no reason my performance was going . I don't think this is normal
       Pumas.EXE has stopped responding...
  • CPU
    RYZEN 5 1600
  • Motherboard
    ASROCK B450 PRO 4
  • RAM
    16GB Corsair Vengeance LPX
  • GPU
    PowerColor RX 5700
  • Case
    Corsair Carbide 275r
  • Storage
    intel 660p 512 GB
  • PSU
    PowerSpec PS650BSM
did the temperature rise? if it did, its just throttling. or something in the background is using the CPU
Im with the mentaility of "IF IM NOT SURE IF ITS ENOUGH COOLING, GO OVERKILL"
CURRENT PC SPECS
CPU             Ryzen 5 3600 (Formerly Ryzen 3 1200)
GPU             : ASUS RX 580 Dual OC (Formerly ASUS GTX 1060 but it got corroded for some odd reasons)
GPU COOOER      : ID Cooling Frostflow 120 VGA (Stock cooler overheats even when undervolted :()
MOBO            : MSI B350m Bazooka
MEMORY          Team Group Elite TUF DDR4 3600 Mhz CL 16
STORAGE         : Seagate Baracudda 1TB and Kingston SSD
PSU             : Thermaltake Lite power 550W (Gonna change soon as i dont trust this)
CASE            : Rakk Anyag Frost
CPU COOLER      : ID-Cooling SE 207
CASE FANS       : Mix of ID cooling fans, Corsair fans and Rakk Ounos (planned change to ID Cooling)
DISPLAY         : SpectrePro XTNS24 144hz Curved VA panel
MOUSE           : Logitech G603 Lightspeed
KEYBOARD        : Rakk Lam Ang
HEADSET         : Plantronics RIG 500HD
Kingston Hyper X Stinger
and a whole lot of LED everywhere(behind the monitor, behind the desk, behind the shelf of the PC mount and inside the case)
Can you post your full systems specs?
Main Workhorse:-
Dual Xeon E5-2687W v3 | SuperMicro X10DAi Dual Socket Workstation Board | 64GB ECC DDR4 2400Mhz | Intel DC Series 500GB SSD | EVGA Geforce GTX Titan X | Seagate 7200rpm 2TB | SuperMicro Gold Series 1Kw PSU | SuperMicro EATX Chassis | LG Ultrawide 34inch 75hz | LG 1080p 22inch IPS 75hz | Ubuntu 19.10 x64 |
Server:-
Dual Xeon E5-2680 v1  | SuperMicro X9DRW-3LN4F+ Server Board | 64GB ECC DDR3 1600Mhz | 7 x Intel DC Series 500GB SSD's | SuperMicro SuperChasis SC119TQ-R700WB 1U | Redundant 450w Gold rated PSU's | ESXi 6.7
Laptop:-
2018 15 inch Apple Macbook Pro Touchbar with 16GB Memory and 256GB NVMe
try monitoring temperatures to see whether the CPU or GPU reaches the Tjunction, but also monitor cpu and gpu usage to make sure there isn't some other app using up resources. If one of the component does reach the Tjunction or is close to it, it basically means that it is overheating and in the process it's lowering it's speed down to prevent damage.
Ryzen 5 1600
16 gb 2133
Rx 5700
intel 660p 500gb M.2 SSD
  • CPU
    RYZEN 5 1600
  • Motherboard
    ASROCK B450 PRO 4
  • RAM
  • GPU
    PowerColor RX 5700
  • Case
  • Storage
    intel 660p 512 GB
  • PSU
    PowerSpec PS650BSM
im not sure I think what I am going to do is turn up the fans in BIOS and see what happens.
  • CPU
    RYZEN 5 1600
  • Motherboard
    ASROCK B450 PRO 4
  • RAM
  • GPU
    PowerColor RX 5700
  • Case
  • Storage
    intel 660p 512 GB
  • PSU
    PowerSpec PS650BSM
